Does anyone know of a project for someone looking to get in the hobby
Home › Forums › Beginners questions › Does anyone know of a project for someone looking to get in the hobby
  • #362374
    Henry Ruiter
      @henryruiter35703
      What I was looking for is a project to get me it to model engineering.
      Thanks Henry
      #9257
      Henry Ruiter
        @henryruiter35703
        #362375
        Hopper
          @hopper
          Elmers Wobbler engine here **LINK**
          is a popular beginner's project.
          #362376
          Henry Ruiter
            @henryruiter35703
            I forgot to say can the measurements be in metric please if possible.
            Thanks Henry
            #362377
            Hopper
              @hopper
              LOL, too modern for me!
              But the Steve's Workshop website has these plans here **LINK** in metric for a simple oscillating engine that can be run on steam or compressed air. Build instructions are here **LINK**
              His website (and the other one by Tom I posted) are both a great source of information for beginners (and not-so-beginners).
              #362380
              doubletop
                @doubletop
                Henry
                A few to choose from here **LINK**
                This is a good starting point. It was my first project
                This is a good little engine, maybe something for #2
                Pete
                #362381
                  Given your interest in traction engines maybe the "Wells" traction engine which was used as a schools project would have more interest for you. I did use some simple castings that were cast at school but these could be made from solid or fabricated and the drawings are in metric. You should be able to download from this post and the casting pattern drawings from this one. You may need to join the forum to see the attached PDFs.
                  Also search the net for "Wells traction engine" or "schools traction engine" to see what it is like and find a couple of build threads
                  Edited By JasonB on 16/07/2018 08:26:47
                  #362424
                  Ian S C
                    @iansc
                    One of the High Schools in Christchurch NZ has run evening classes for many years making a similar traction engine to the one shown by JasonB.
                    Ian S C
                    #363158
                    Henry Ruiter
                      @henryruiter35703
                      Is there a water pump I could make.
                      Thanks Henry
                      #363168
                        Very in depth beginners article on making a small hand feed pump has just been in ME
                        #363181
                        Henry Ruiter
                          @henryruiter35703
                          I was thinking more along the lines of a centrifugal water pump.
                          Thanks Henry
                          #363206
                          steamdave
                            @steamdave
                            Posted by Henry Ruiter on 21/07/2018 09:30:34:
                            Thanks Henry
                            Have a look at http://www.john-tom.com/html/ElmersEngines.html
                            Scroll down to no.12 and there you will find a simple turbine and centrifugal pump combination. You can make the pump without the turbine. The drawings and machining notes are a .pdf file.
                            The Emerald Isle
                            #363425
                            Jeff Dayman
                              @jeffdayman43397
                              Elmer's Turbine and Pump would be an excellent beginner project Dave, as would many of Elmer's engines on Jon Tom. However the OP complained before when someone suggested one of Elmer's engines because they weren't metric…..
                              …Even though 1" = 25.4 mm and calculators are not hard to come by.
                              ….Even though #2-56 is very similar to M2, #4-40 is very similar to M3, #8-32 thread is very similar to M4, #10-32 is very similar to M5, etc.
                              No reason Elmer's simple plans with relatively few dimensions could not be easily converted to metric for one's build with just a minor effort.
                              #363428
                                Could make it a little bit bigger and use 1/32" = 1mm that way you will get mostly whole metric sizes.
                                #363481
                                Jon Lawes
                                  @jonlawes51698
                                  As a beginner myself I'm finding a lot of the things I am interested in take a little searching, or research, or conversion into a useful scale or size. It's a great deal of the pleasure, not much is "on a plate".
                                  #363484
                                  Jon Lawes
                                    @jonlawes51698
                                    This seems like a good starter, something like that would be ideal. Did you manage to get a lathe in the end?
