DIY drive belt
DIY drive belt
Home Forums General Questions DIY drive belt
  • #22036
    Takeaway
      @takeaway
      Takeaway
        @takeaway
        I have lashed up a grinding machine using a diamond cup wheel to touch up my carbide lathe tools but the nylon camera bag strap that I have made the drive belt from is far to thick and the glued area where I joined it makes it "lump" over the pullets ( 22m dia. and 50mm dia).
        My question is, do any of you know of a thin, tough and flexible material,preferably something that I could reinforce by stitching (say 1/64" – maybe a little thicker) in sheet form that I could cut and join to make a drive belt approx. 1" wide? I would need a length of about 18" to form the loop.
        Stuart
        #86687
        Speedy Builder5
          @speedybuilder5
          Why don't you use a toothed belt turned inside out ?
          #86691
          Ian P
            @ianp
            Best candidate for jointless flat belts is PolyVee turned over. It will run much quiter and smoother than the back of a timing belt.
            Suppliers stock the belting as a wide band (500mm?) and slit it to suit the number of grooves on the pulleys. I have one with only 3 ribs so its less than 8mm wide
            Ian P
            #86693
            Ex contributor
              @mgnbuk
              It will probably offer more grip that way round as well ! wink
              Flat belts should be available from any good bearing / transmission supplier.
              #86722
              Ian S C
                @iansc
                There is a heat joinable belting, I think it is used for tool post grinders, and other high speed applications, I think its best to give the supplier the measurements, and let them join it, I think it's more difficult than the round belts. Ian S C
                #86813
                john fletcher 1
                  @johnfletcher1
                  Redthane round plastic belting.Heat up a broken hacksaw blade or old knife,push the two ends onto the heated blade pull away and push the two melted ends together, must be held in line for 5 or 10 minutes leave over night.Next morning remove plastic flashing with a sharp knife and smooth up with some course sand paper. Very quiet in operation. I believe they make a Greenthane as well its small diameter, Ted
                  #87275
                  Takeaway
                    @takeaway
                    Thanks to all for info and help. Have managed to sort the belt problem and the result can be seen here if you are interested.
                    http://chuck-it-in-the-pot.blogspot.com/
