Display track
Display track
Home › Forums › Locomotives › Display track
  • #355630
    John Rutzen
      @johnrutzen76569
      Hi, does anyone know where I can get the parts to make a length of realistic looking display track for 31/2 and 5 inch gauge locomotives please?
      #1721
      John Rutzen
        @johnrutzen76569
        #355638
        KWIL
          @kwil
          #355639
            Blackgates and Polly Eng also do display track.
            #355646
            John Rutzen
              @johnrutzen76569
              Thanks for the replies. I can't find it in Polly or Blackgates catalogues so I have emailed them. I can get it at the other suppliers but it is very expensive. I can make wooden sleepers easily enough, all I want is short lengths of rail which will post. Maybe i'll have to mill them from steel bar.
              #355650
              Bazyle
                @bazyle
                If you are after steel rather than aluminium then you will find it significantly more expensive, if available. It is also going to mostly be flat bottomed in aluminium as the bulk use is for running tracks Flat bottomed steel would be much more difficult to make.
                #355652
                Nick Hughes
                  @nickhughes97026
                  Did you find these:- **LINK**
                  on your search?
                  #355686
                  Speedy Builder5
                    @speedybuilder5
                    What are the thoughts about running on rectangular section steel bar instead of railhead section ?
                    BobH
                    #355688
                    John Rutzen
                      @johnrutzen76569
                      Thank you Nick that looks about the best one. I think quite a lot of tracks used to be rectangular steel bar. I know when I was a member of York MES in the 1960's that was what they used.
                      #355705
                        I made a short 'test track' out of rolled black bar with rounded sides.
                      Home › Forums › Locomotives › Topics
