Digital Read Out Optical scales (cheap ones on Ebay
Home Forums Workshop Tools and Tooling Digital Read Out Optical scales (cheap ones on Ebay
  • #341668
    jimmy b
      @jimmyb
      I'm giving some thought to fitting a set of the cheap Optical scales off Ebay **LINK** to put on my Sieg SC4
      Has anyone tried a set of these??
      I've been making do with a calipers on magnets up till now…
      JIm
      #18849
      jimmy b
        @jimmyb
        #341669
        Samsaranda
          @samsaranda
          Be Aware the item you refer to is despatched from an address in China.
          Dave W
          #341672
          Andy Holdaway
            @andyholdaway
            I have the same make (although 3 axis) on my milling machine, and have had no problems at all. The manual isn't the best but it's virtually the same as the Sino DRO's of which there are a couple of English re-writes if you Google it.
            Andy
            #341673
            jimmy b
              @jimmyb
              Buying from China is safe enough for me. Even with duty etc, it’s not a bad price.
              Jim
              #341674
              David Colwill
                @davidcolwill19261
                No experience of that particular item but I have had a Sino DRO fitted to my lathe for 10 years or so and another supplied by the DRO Store ( China based eBay supplier ) on my mill for 6 years. The only problem I have had is dirt in the Z axis scale on the lathe. This was cleaned and it has worked ever since.
                Regards.
                David.
                #341679
                jimmy b
                  @jimmyb
                  I’ve got a Sino on my other lathe. I wouldn’t be without it now.
                  Can’t justify too much cash on the second lathe.
                  Jim
                  #341682
                  Oldiron
                    @oldiron
                    Hi Jim. There is an install by thecogwheel on what I believe is the same item here. :- **LINK** Might be of some help.
                    regards
                    #341684
                    jimmy b
                      @jimmyb
                      I heard the podcast and watched the video on it!
                      Cogwheel is on of my favourite podcasts. Proper mix of stuff
                      Jim
                      #341688
                      Brian Rutherford
                        @brianrutherford79058
                        I bought a 2 axis set from china off the bay. The supplier was very good and will use the same when i do my mill.
                        Ended up paying £20 extra on duty and paperwork by fedex. Instruction manual is appalling but fitting on my warco was straightforward. No problems with quality and reliability and lets face if just about every computer motherboard is made in china.
                        #341703
                        colin brannigan
                          @colinbrannigan54160
                          I bought a 3 axis DRO from China in 2016, seller was cncmotor on the bay cost was about £220, arrived on time and has proved to be faultless. Need a two axis now for the Myford super 7.
                          #341735
                          jimmy b
                            @jimmyb
                            Just about to order the Ebay kit, went in the shed to double check sizes and realised I'd over looked the gib screws! The Crusader has wedge gibs, so I'd not even given the gibs a thought!
                            Now, do I just stand off from the gibs and remove the DRO to adjust them (although I honestly can't remember the last time I adjusted them) or do i mount it above????
                            Jim
                            #341747
                            David George 1
                              @davidgeorge1
                              Hi Jimmy have you thought of fitting the scale to the base casting and the smaller reader head to the moving casting.
                              David
                              #341868
                              I.M. OUTAHERE
                                @i-m-outahere
                                I have ordered 3 sets from China , all off ebay and i think all are mtech units .
                                One came from dro pros or the dro store or something like that and it had better quality mounting hardware like brackets machined from alloy extrusions and the others had cast brackets – other than that they are identicle and have given no problems . Just beware of free shipping as it won't have tracking or insurance so check to see who is carting your prized possetion to you , mine were via Toll transport and arrived inside 3 days to Australia but cost me $30 au postage – well worth it i thought .
                                Get ready to learn a new language so you can read the manual though !
                                Ian
                                #342097
                                jimmy b
                                  @jimmyb
                                  Well its tuned into a non starter!
                                  I have been forced to abandon this plan! I mocked up some cardboard dummy reader bars. The problems kept coming! Every time I found a solution to a problem another one popped up.
                                  The gib screws and the saddle clamp have ended the project. The gains are not worth the losses. I was moving the reader higher and further out.
                                  I will carry on with what I have, clock on cross slide and 6" caliper on bed.
                                  Thank you for the input.
                                  Jim
                                  #342122
                                  I.M. OUTAHERE
                                    @i-m-outahere
                                    On one of my lathes i had to mount the scale on some custom brackets off the end of the cross slide , the scale body is mounted on a piece of 30 mm sq tube that is bolted to the cross slide and the reader head iis mounted to the saddle with a solid angle bracket . It doesn't look pretty but it works , i have found some super slim scales (easson I believe ) jjust not sure it will work with my display though .
