Dickson QCTP Holders
Home › Forums › Workshop Tools and Tooling › Dickson QCTP Holders
  • #19033
    Harry Wilkes
      @harrywilkes58467
      #366548
      Harry Wilkes
        @harrywilkes58467
        I have watched a few YouTube videos of people making the single dovetail type toolholders and was wondering if anyone as made the Dickson type toolholder for use on the Myford S7 ?
        Cheers
        H
        #366559
        peak4
          @peak4
          I think Thaiguzzi, if you search through his posts/photos
          Got the same job to do myself at some point, as I've just bought a 90° horizontal milling cutter for the grooves.
          Bill
          #366564
          Kerrin Galvin
            @kerringalvin72662
            Hi Harry,
            I measured up my existing tool holders, averaged them out, draw up in CAD & took the file to a water cut company, 2 days latter they rang to say the first one was done, would a care to come & pick it up & give it a try before they did the rest. I fitted great! No adjustment needed.
            Cheers Kerrin
            #366572
            thaiguzzi
              @thaiguzzi
              Yeah, mine were for my Boxford. Have made 19 in total so far, 11 in steel and 8 in aluminium ('cos i ran out of steel…).
              #368265
              John Reese
                @johnreese12848
                Getting the correct fit on a Dickson type tool holder is a lot more difficult than on an Aloris style holder. On the Dickson there are two Vs that have to be parallel and an exact distance apart. I admire those who are up to that challenge.
                #368269
                Grotto
                  @grotto
                  I'm also planning to have a crack at making some.
                  I bought some from AR which are great. Topped up with a few more from RDG or Chronos, but there was a fair amount of variability between them, some perfect, others not so. The AR ones are much harder steel which is good unless you want to mill a bit off them so you can use 12mm shank tools.
                  Videos make it look so easy, but from experience it never turns out that way (for me).
                  #368271
                  thaiguzzi
                    @thaiguzzi
                    wink 2yesPosted by John Reese on 21/08/2018 00:08:34:
                    #368328
                    RICHARD GREEN 2
                      @richardgreen2
                      Harry,
                      Have a look at my post "MAKING QC TOOL HOLDERS" ,
                      Go on……………have a go.
                      Richard.
                      #368332
                      Tony Pratt 1
                        @tonypratt1
                        Posted by thaiguzzi on 21/08/2018 07:20:13:
                        Not that difficult for a careful machinist, a mill with a tilting head would have no problem. Some people think dovetails are difficult as used on the Aloris style, so pros & cons for both types.smiley
                        Tony
