Well Dave, whatever about the screw tips, the heads are in a sad state !
The other six screws came out clean, with no damage, just the last two.
There seems to be no way to remove the block, so I am devising a way to clamp the machine minus the tables on the mill, while making up a jig to guide a drill or endmill or whatever. I am hoping to use some of the other holes to hold this jig in position.
The other option might be spark eroder, not sure where I can get this done, but will ask around.
The blades are rusted but not gapped as far as I can see [this machine was not too well cared for ], so could be reground or at worse, replaced, they are not too dear anyway.
Sad to see a good machine end up like this.
I am also restoring a 16mm bench drill, and the less said about its condition, the better !
Enough to say that had a few more holes been drilled in the table it might have fallen off !
