The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › General Questions › Cylinder Head Combustion Chamber Template
If you have some gash vales you could use them?
Clean the faces, place in the valve guides, add glue to the faces.
Position your template and then turn the head over so the valves sit on the template whilst the glue sets
Dave S is about right.
The simple way would be to do it as Dave suggests but simply glue the valves to a sheet, cutting out later after transferring the required outline to the sheet. KISS principle at work?
Trying to do it after cutting out the shape is wasted energy.
Clearly needs two making.
… if you really must ignore Mr Vizard’s illustration and make your template non-flippable.
What was that about keeping it simple ?
I hope that head will get skimmed, it looks rather like it's been used as a boat anchor and then sandblasted.
TBH it’s better not to glue the valves to the template as you say.
This was bought as a scrap head (cost me £15 post), should have seen it before I cleaned it up. The idea was to use thins for practice.
Once the template was made it would be a simple matter to use a transfer punch or drill bit through the valve guides to mark the hole locations.
Started by: Andrew Tinsley in: General Questions
Andrew Tinsley
Started by: Werner Schleidt in: Exhibitions, Shows and Club Events
Pete
Started by: Dalboy in: Materials
bernard towers
Started by: Graham Meek in: Manual machine tools
Started by: engineeredbyhansson in: Manual machine tools
engineeredbyhansson
Started by: Speedy Builder5 in: Workshop Tools and Tooling
old mart
Started by: Geoff Dunsby in: CAD – Technical drawing & design
Geoff Dunsby
Started by: BOB BLACKSHAW 1 in: CAD – Technical drawing & design
renardiere7
Started by: JasonB in: The Tea Room
Bazyle
Started by: Chris Kirby 1 in: Help and Assistance! (Offered or Wanted)
Macolm
Started by: Michael Gilligan in: Manual machine tools
southernchap
Graham Meek
Started by: BOB BLACKSHAW 1 in: The Tea Room
Martin Connelly
Started by: Phil Whitley in: The Tea Room
Phil Whitley
Started by: point.two.five in: Introduce Yourself – New members start here!
point.two.five
Started by: leeboxford280t in: Manual machine tools
John Hinkley
Started by: ian Holdsworth in: Beginners questions
Paul Lousick
Started by: Garry Coles in: General Questions
Nigel Graham 2
Started by: Peter Simpson 3 in: Beginners questions
Started by: Clive Farrar in: General Questions
Started by: daz996 in: Beginners questions
5sahib
Started by: Graeme Seed in: Workshop Tools and Tooling
Speedy Builder5
Started by: Ian Parkin in: The Tea Room
not done it yet
Started by: Pippin in: Work In Progress and completed items
