Mine are cast iron since I bought castings, and it's prototypical. The front cover is just a flat plate, so if I hadn't bought a casting I would have used some hot rolled plate as it distorts less than cold drawn, and seems less prone to corrosion. For the rear cover anything other than a casting would have been a right pain:
The expansion rates of low carbon steel and cast iron are pretty similar.
