Cutting the end off a carbide endmill
Home › Forums › General Questions › Cutting the end off a carbide endmill
  • #25415
    David Colwill
      @davidcolwill19261
      #310467
      David Colwill
        @davidcolwill19261
        Hello,
        I have a selection of carbide endmills that I picked up for next to nothing because they have chips on the ends. I had thought that I may be able to lop the ends off with a 1mm abrasive cutoff disc but having tried it, it is not going to work.
        I therefore need to find some other way, presumably involving diamonds. I tried an old tile cutting blade but that wasn't any good either.
        Has anyone used anything particular or have any recommendations. I don't mind spending money on the right thing but would like some assurance of success before splashing out.
        Ideally I would want something 100mm diameter but I could probably accommodate 115mm at a push.
        Many thanks in advance.
        David.
        #310471
          David Colwill
            @davidcolwill19261
            Thanks for that. I hadn't seen those on Arcs website. For that price they have to be worth a punt.
            David.
            #310476
            Angus Anderson 1
              @angusanderson1
              You could try a diamond grinding cup wheel off ebay:
              http://www.ebay.co.uk/itm/Grit-180-Diamond-Aluminum-Resin-Bowl-Shape-Grinding-Wheel-150mm-OD-Cutting-/262887397955?epid=1573188159&hash=item3d354f5a43:g:T6cAAOSwCU1YwSo7
              I bought one of these and mounted it on my bench grinder, I had to turn two clamping adaptors so it would fit and run true on the grinders shaft. Other diameter wheels are available. It is brilliant for touching up HSS and carbide tools. No signs of wear after 1.5 yrs use.
              Angus
              #310504
              David Standing 1
                @davidstanding1
                Posted by Angus Anderson 1 on 05/08/2017 11:03:23:
                Angus
                Unless I have completely misread the first post, David doesn't want to sharpen the end mills, but cut them off.
                #310506
                Andrew Entwistle
                  @andrewentwistle
                  Hi David,
                  I have used the type of diamond disc that Neil linked to, dry, at about 10000 rpm with a Dremel to gash a 5 mm carbide endmill that I had sharpened the same way Angus does. The disc made short work of the gashing and could easily have sliced right through the 5mm carbide cutter.
                  Andrew.
                  #310513
                  David Colwill
                    @davidcolwill19261
                    Thanks for the replies.
                    I've ordered a couple of the 100 mm discs from arc and will report back soon.
                    Many thanks.
                    David.
                    #310521
                    Vic
                      @vic
                      What are you planning to do with them David?
                      #310524
                      John Reese
                        @johnreese12848
                        I use the diamond plated discs in a dremel tool. It only has one layer id diamond on the edge so life isn't great. I use them for cutting off the end mill. I have some 4 1/2 discs about 3/32 thick that are diamond plated. I use them for gashing the end of the cutter. Life of these seems to be ok. I have some masonry cutoff discs for my angle grinder that have been unused for many years. I thought I would try them for gashing and see how they work. I will reportbak on how they work.
                        #310536
                        Niels Abildgaard
                          @nielsabildgaard33719
                          I grind a v-shape notch .5mm deep all way round,clamp in vice and use a hammer.
                          Carbide is brittle like glas or diamond.
                          Edited By Niels Abildgaard on 05/08/2017 17:33:46
                          #310633
                          David Colwill
                            @davidcolwill19261
                            Once I have cut the end off I can resharpen them
                            David.
                            #310946
                            David Colwill
                              @davidcolwill19261
                              A quick update on this.
                              The discs arrived this morning and I used one to lop 10 mm of a 20 mm carbide endmill. I'm not sure how long they will last doing this kind of duty but at that price,,,,,
                              Many thanks for the input especially Neil for the link to Arc.
                              David.
