Cutting/boring bush
Cutting/boring bush
Home › Forums › Workshop Tools and Tooling › Cutting/boring bush
  • #312754
    Col21
      @col21
      What sort/shape should a cutter be boring out a copper coated bush in a milling machine. Was going to use a piece of 6mm hss.
      #18619
      Col21
        @col21
        #312755
        Nick_G
          @nick_g
          When you say coated. How thick is the coating and what is the base material under the coating.?
          I ask this as if it's not a very thick coating you may be able to get under it in the first pass.
          Are you also sure the bush is copper.?
          Nick
          #312756
          David Standing 1
            @davidstanding1
            And, following on from Nick's post, are you sure it isn't an oilite bush?
            #312760
            Col21
              @col21
              It's a copper coated small end bush. I assume it'll be steel. Only got to remove about 0.4mm
              #312762
                What size is the bore as that will determine what sort of tools will fit down the hole.
                Do you have a boring head?
                #312771
                Col21
                  @col21
                  50mm bore by about 50mm deep. Yeah a vertex adjustable boring head which has 18mm holes
                  #312774
                    Piece of 18mm bar drilled across at the end to take your 6mm HSS toolbit and then cross drilled for a grub screw say M5 to retain the bit. Should be nice and rigid which will help keep the bore parallel.
                    #312775
                    Col21
                      @col21
                      Thanks yeah that what I was thinking but what shape should I grind the cutter to get the best result. I.e. Large radius , relief and speed etc
                      Edited By Rocketman on 18/08/2017 18:59:45
                      #312778
                      HOWARDT
                        @howardt
                        Is it a Glacier bush, or whatever they call themselves these days. They make steel backed bushes with various bearing materials. If it is then it can be pushed out and a replacement fitted, no matching necessary.
                        #312795
                          Click the "988 photos" under my avitar and look in the "sketches" album, there are 4 photos there of a between ctrs boring bar numbered bb1-4 they show a suitable cutter profile.
