cutting 20tpi on clarke cl430
Home › Forums › Workshop Techniques › cutting 20tpi on clarke cl430
  • #15803
    mick70
      @mick70
      #202968
      mick70
        @mick70
        as anyone cut above thread?
        listing in manual starts at 22 tpi up to 40.
        thanks
        #202969
        mick70
          @mick70
          don't worry had another look and it's numpty operating lathe that read it wrong.blush
          #202975
          Bazyle
            @bazyle
            In general when you have this sort of thing look for a thread you do have the settings for that is a simple multiple like 2:1 or 3:2 as you can probably modify part of the gear train to provide the ratio.
            #202978
            mick70
              @mick70
              Set it up per manual and comes out really coarse thread.
              Going to have another look tomorrow as might end up using hammer on it.
              t
              #202979
              Keith Long
                @keithlong89920
                Try looking in the second column of the changewheel / tpi chart, bottom row, with the speed selector lever set to position 2 ie handle to north east.
                #202980
                mick70
                  @mick70
                  I did.
                  Even stripped them all of to double check I had put right gears in.
                  Got it running on its slowest speed as well.
                  #202986
                  Bazyle
                    @bazyle
                    The chart in the manual is looking a" bit crap".
                    It gives, for 20 tpi 50/36 56/27 that speeds up the leadscrew so cuts a coarser thread than the leadscrew.
                    What is the leadscrew pitch?
                    #202996
                      Posted by Bazyle on 02/09/2015 21:28:52:
                      It gives, for 20 tpi 50/36 56/27 …
                      Bazyle,
                      Did you spot Fig.21 on the next page of the manual ?
                      It shows a reduction before gear 'A' … so that's not the full train.
                      Edit: I just found the Parts List … which may be useful
                      Edited By Michael Gilligan on 03/09/2015 00:01:02
                      #202997
                      Bazyle
                        @bazyle
                        AH, well spotted but it is the pair behind A in permanent position that are the extras, and look to be 2:1. It must have a metric leadscrew as the metric .table aligns quite well, but not accurately to a 3mm pitch.
                        #202999
                        Bazyle
                          @bazyle
                          You struck unlucky with choosing 20tpi. The relative ratios of all other threads, metric or imperial are correct one to another, except for the 20 tpi setting. It is over 30% off. Not sure if the starting position is quite right still as I think that fixed pair I mentioned above need to be 16/35 (or 32/70 ) with a 1.5mm leadscrew, ie not quite 2:1.
                          #203000
                          mick70
                            @mick70
                            cheers for replies.
                            be glad when i get full set of gears for southbend.
                            #203004
                              Exploded View in the parts list appears to show both a double gear and a triple … this could get complicated.
                              Probably worth turning the headstock spindle by hand, and counting turns of gear 'A' to establish a baseline.
                              mick70
                                @mick70
                                right just been out to reset it for normal turning.
                                had a look at chart on inside of cover and it gave a totally different set of gears.
                                gave it a go and worked great.
                                gears it listed were
                                a=50
                                b=36
                                c=56
                                d=42
                                #203008
                                  Excellent Result !!
                                  #203027
                                  mick70
                                    @mick70
                                    sent clarke e-mail explaining.
                                    they say they will look into it and if required update manual to match.
                                  Home › Forums › Workshop Techniques › Topics
