Cross Slide Micrometer
Home › Forums › Beginners questions › Cross Slide Micrometer
  • #302569
    Martin Faulkner
      @martinfaulkner67684
      Afternoon all,
      Hope all is well. I have come across another issue on the Boxford lathe, i am unable to remove the micrometer dial off the cross slide feed screw. the tool post one slides off when the 2 grub screws are removed. Does anyone know how it comes off? it will not turn on the shaft like the one on the tool post. It is having a good soak in WD40 for a while.
      Any help would be much appreciated.
      #8751
      Martin Faulkner
        #303185
        Robbo
          @robbo
          Martin
          The cross-slide arrangement is similar to that on the compound (top slide).
          The dial has those two grub screws, under which are spring loaded brass pads which bear on the feedscrew.
          The nut which needs a split screwdriver, on the end of the feedscrew holds the handle on.
          Take off the handle remove the grub screws, and springs – the brass pads won't come out until the dial is removed – and the dial is free to move on the feedscrew. That's the theory. In practice it may be stuck on the screw by the brass pads, and turns the feedscrew. It is necessary to hold the feedscrew and twist the dial to and fro to release it.
          If you take off the two socket cap screws holding the mounting onto the end of the cross-slide then you can wind the feedscrew out until a "grippable" bit appears. Don't over do it.
          And don't lose the teeny weeny springs and the brass pads.
