Countersink bits
Countersink bits
Home › Forums › Workshop Tools and Tooling › Countersink bits
  • #530497
    Bo’sun
      @bosun58570
      Good morning,
      When using HSS "rose" style countersink bits to countersink and chamfer holes in mild steel, how do I prevent them chattering? It occurs with both machine and hand operations.
      It doesn't happen all the time, but when it does, it's impossible to correct.
      I guess speed and lubrication might be the main considerations.
      #20177
      Bo’sun
        @bosun58570
        How to prevent chatter?
        #530498
          Try putting a small piece of thin cotton fabric between the cutter and the work.
          P.S. 1, 2 or 3 flute cutters are usually less troublesome
          Edited By Michael Gilligan on 27/02/2021 11:30:15
          #530499
          Rod Renshaw
            @rodrenshaw28584
            I think I read somewhere that rose bits were really woodworkers' tools.
            Single cutting edge countersink bits, of which there are several patterns, cut mild steel without chattering.
            Rod
            #530502
            Bo’sun
              @bosun58570
              Thank you Michael. Now you mention it, I remember one of the guys at work using a piece of spent emery cloth.
              Rod. I did try the "snail" type bits, and they worked realy well, but they didn't appear to be very hard. Probably meant for woodwork. I'll do a search and see if I can find them in HSS.
              #530503
              Howard Lewis
                @howardlewis46836
                In my experience, Chamfering tools chatter unless the speed is kept low, and fed very gently.
                The 1/2 " one is better than the 3/4" when they are used in the 3 MT Tailstock..
                #530506
                Emgee
                  @emgee
                  Posted by Bo'sun on 27/02/2021 11:22:46:
                  Good morning,
                  Hi Bo'sun
                  I have experienced the same but found low speed (200) and lube with 1 good hit does the job and leaves a smooth finish if countersinking, for de-burring of small holes I use the same cutter but held in a chuck and operated by hand.
                  Emgee
                  #530509
                  Mike Hurley
                    @mikehurley60381
                    After years getting oval, off centre or chattered countersinks with these type of cutters, I now get pretty well 100% success with the following 'rules'
                    1. Work firmly clamped down
                    2. Slow speed
                    3. (Probably the key one) be decisive! By this I mean, decide on your depth of countersink, set your stop on the drill press or equivalent on lathe/mill, then 'drill' in ONE FIRM motion to full depth. It always seemed to be the intermittent and 'bit less / or a tiny bit more' approach that causes issues.
                    regards. Mike
                    #530511
                    Hollowpoint
                      @hollowpoint
                      While we are on the topic of countersink bits does anyone have any recommendations for good value/performance?
                      I always found the cheap ones are shockingly bad and the good ones are shockingly expensive. frown
                      #530515
                      Emgee
                        @emgee
                        Posted by Hollowpoint on 27/02/2021 12:13:09:
                        You can make your own single point from silver steel hardened of course, just make sure you back off to give clearance.
                        Or if you have access to a tool grinder do the same from HSS.
                        Emgee
                        #530518
                        Bill Phinn
                          @billphinn90025
                          The range of Sherwood single-flute csks from Zoro are excellent in performance and value.
                          Alpen three-flute csks give very good performance as well though are a little pricier.
                          Machine countersinking shouldn't cause chattering as long as you keep the speed and downfeed pressure low, and have good stiffness in the set-up. I tend to use Vactra no.2 as a lubricant, when I do use a lubricant.
                          Edited By Bill Phinn on 27/02/2021 12:46:23
                          #530524
                          bernard towers
                            @bernardtowers37738
                            I use the through hole ones in various sizes as I have zero success with any that have more than one cutting edge, and speed is definitely a factor.
                            #530540
                            Philip Rowe
                              @philiprowe13116
                              Since I switched to using spotting drills instead of centre drills, I have found that they also make excellent countersink bits with no chatter at all.
                              Phil
                              #530547
                              Douglas Johnston
                                @douglasjohnston98463
                                Posted by Philip Rowe on 27/02/2021 13:41:43:
                                Phil
                                +1 for that. I discovered this quite recently after buying a set of various diameter 90 degree spotting drills on the bay. They cut a treat and give a very neat countersink if you pick one just a tad bigger than the screwhead.
                                Doug
                                #530558
                                Martin Dowing
                                  @martindowing58466
                                  There are *asymmetrical* countersinks where 3 segments with cutting edges are at different angles to each other.
                                  This design is implemmented explicitly to reduce / prevent chatter.
                                  Martin
                                  #530577
                                  Henry Brown
                                    @henrybrown95529
                                    The RDG 3 flute ones are good. I've got a few, 25mm is the largest, they need to be run slowly with lots of cutting oil, I use CT90.
                                    #530590
                                    Georgineer
                                      @georgineer
                                      Posted by Martin Dowing on 27/02/2021 16:13:26:
                                      Martin
                                      Dad had one he made when he was an apprentice which had just one 'tooth' at a different angle from the others. It was a delight to use. I think one of my brothers had it when we sorted out Dad's workshop.
                                      George B.
