Convert cheap digital calliper to height gauge?
Home › Forums › Workshop Techniques › Convert cheap digital calliper to height gauge?
  • #49316
    marcusj
      @marcusj
      Has anybody got any plans / tips for converting a cheap digital calliper for use as a height gauge for marking out in combination with a surface plate?  Was there ever a MEW article on this?
      #15457
      marcusj
        @marcusj
        #49318
        keithmart
          @keithmart
          Hi
          MEW 8 has the article
          regards
          Keith
          Leeds UK
          #49332
          trevor jones 1
            @trevorjones1
            febuary 2010 MEW 160 has plans for home made height gauge.
            Trevor.
            #49340
            NEIL SMITH 1
              @neilsmith1
              On  minilatheworkshop.com,there are several height gauge conversions with good photos.
              #49343
              Les Jones 1
                @lesjones1
                Hi Marcus,
                                     There was a recent discussion on the “Yahoo GriZHFminimill ” forum dealing with this subject. This is one design mentioned there.
                Hope this helps.
                Les
                #49344
                NEIL SMITH 1
                  @neilsmith1
                  Hi Les,that is one from minilatheworkshop.
                  #49345
                  Gep Engler
                    @gepengler40547
                    Hi Marcus,
                    Here, you can find a few pictures of the height gauge I made last year:
                    Cheap indeed: now and then these digital calipers are here in the shops for about 9 Euros. No Mitutoyo, but good enough for me!
                    Regards from The Netherlands and success with your conversion,
                    Gep
                    #49346
                    Stewart Hart
                      @stewarthart90345
                      You can also make them into good depth gauges
                      Stew
                      #49356
                      marcusj
                        @marcusj
                        Now found one in MEW issue 25, too.  Wow, lots of plans for these about when you start looking!
                        #49582
                        Clive Farrar
                          @clivefarrar90441
                          If you use the MEW drawings make sure you READ them thoroughly first.
                          The base section is incorrect as drawn.  It shows the clamp thread hole going through the mounting step.  Look at the photo up and right in the article and you will see where it should be. The CL is 10.50  mm from the face oposite the step.
                          David has been e mailed but these things take time to be published.
                          But it does work as I have made one from scrap bits. I am pleased with it for the amount of use it will get it is a good infill job and has saved me from “collecting” another expensive instrument just in case I might need it.
                          I also got a 2nd vernier from Aldi so that I can have a settign on one and the other for free measurements.
                          Regards Clive
                          #49583
                          Clive Farrar
                            @clivefarrar90441
                            if you follow the MEW article please be aware that the base drawing is incorrect.
                            It shows the threaded hole being bisected by the mounting face.
                            If yo look at the little picture just up and right you will see the correct position.
                            i.e. CL 10.50 mm up from the face without the step.
                            I got a second vernier from Aldi for £8 so i can now have one mounted or in a fixed measure leaving the other free for general use.
                            Regards Clive
                            #49584
                            Clive Farrar
                              @clivefarrar90441
                              Sorry for posting twice it seemd to dissapear the first time
                              clive
                            Home › Forums › Workshop Techniques › Topics
