Compressor tooling connections
Home › Forums › Workshop Tools and Tooling › Compressor tooling connections
  • #319109
    choochoo_baloo
      @choochoo_baloo
      I have an oldish air compressor that was fitted with a cheap flimsy airline and fittings. Just got around to replacing the airline with a quality flexible 'hose' and the air hissing has already disappeared.
      The next job is to replace the original 'quick connect' fittings with better ones.
      My question: is there a convention for having either a male or female quick connect on the air hose (and thus the opposite on each interchangeable air tool)? I ask since the air tools I've seen in a local shop seem to be mostly female quick connect, and wondered if there is a mechanical reason for this.
      Any advice gratefully received.
      #18669
      choochoo_baloo
        @choochoo_baloo
        #319112
        Nick_G
          @nick_g
          Posted by choochoo_baloo on 28/09/2017 14:25:01:
          All mine have a male connector on them like the image.
          Nick
          #319115
          Baldric
            @baldric
            Normally it is the male on the tool as many of the female connectors are self-sealing when nothing is plugged in to them, thus easy to change tools without turning the air supply off.
            Baldric
