Collet Steel
Collet Steel
Home › Forums › General Questions › Collet Steel
  • #309611
    ChrisH
      @chrish
      Just out of interest does anyone know what steel collets are made from?
      I have some collets for my lathe. They are thin walled and springy and hard too as they don't take marks, so obviously not your average EN1A steel. I did wonder if they had been heat treated after manufacture and the reground, but I really don't know how they are made or from what material, hence the opening question.
      Chris
      #25404
      ChrisH
        @chrish
        #309618
        Thor 🇳🇴
          @thor
          Hi Chris,
          I have made some spare collets to be able clamp some odd diameter work, I just used silver steel and didn't harden/temper it. Since the silver steel is harder than mild steel even if not hardened my homemade collets have survived for many years. You could probably use something like EN8 or EN24, not as easy to machine as EN1A of course.
          I assume commercial collets are hardened, tempered and ground.
          Thor
          #309666
          ChrisH
            @chrish
            Thanks Thor – just bumping this up to the top again…….
            #309668
            MW
              @mw27036
              I've made split one way, threaded shank 15 degree taper collets for my trent pinion mill in the past, and I made these all out of 19mm .303 stainless steel. I've never had a problem with them,
              I machine the body first, backwards facing so that I can finish with the screw cut for the shank, otherwise I can't grip the taper backwards to machine it due to the angled face, so I drill to size whilst machining it and finish with a reamer, once I've parted off I would then stamp the size on the face with very small 1.0mm number stamps, this has to be done in a quick 15 degree angle jig I made, and before the splits are machined so as to not damage the collet whilst stamping.  Then I use a small slitting saw and rotary table on the mill to split the collet, then it is finished.
              As you can tell, I got this process down to the tee eventually because of how many I needed to make.
              Like others have said, if I was going to make a much bigger collet that would fit my MT4 lathe, then i'd probably use EN8, I wouldn't bother with any treatment for what we do.
              The professional ones are always ground rather than machined these days, and are probably always some kind of nickel bearing alloy steel.
              Michael W
              Edited By Michael-w on 31/07/2017 21:25:36
              #310226
              ChrisH
                @chrish
                Interestingly, I have just read in L.H.Sparey's excellent book "The Amateur's Lathe" a section on collets complete with a drawing of an adapter assembly to fit on a lathe nose plus collets, and to make the collets he suggests using "collet steel or nickel steel such as old car back axels". Ah, those were the days when you could scavenge in a breakers yard for stuff! But it sort of answers the question.
                Chris
