Collet Chuck set.
Collet Chuck set.
Home › Forums › Beginners questions › Collet Chuck set.
  • #75493
    Ed Duffner
      @edduffner79357
      Hi Everyone,
      I am new to the Model Engineer forums and also to machine tools. I’ve recently purchased a milling machine and a 2MT collet chuck set to go with it. I’ve included some photos below.
      The issue I have is, if I rotate the collet so that it slides further into the chuck, the clamping nut will screw on all the way without tightening the collet and the collet spins around freely.
      The only way I can get a collet to tighten onto a cutting tool is to put the collet in so that “Side A” (in the bottom photo) rests against the grub screw. But this seems a very insecure way to hold a collet.
      Could somebody kindly explain how this particular chuck is supposed to hold its collets please? I can take more photos if necessary.
      Many thanks,
      Ed.
      Inside view showing the side mounted grub screw.
      #5674
      Ed Duffner
        @edduffner79357
        #75494
        Phil P
          @philp
          Can you confirm that you have inserted a screwed shank cutter into the collet ?
          The idea is that the centre hole in the back end of the cutter bears against the male centre in the chuck. The grub screw is there to prevent the collet turning when you tighten it up, and the shoulders should go down past the grub screw.
          Edge A should never touch the chuck body, all the end load is through the actual cutter and onto the male centre.
          Have a google for “Clarkson Autolock Chuck” and you will find more info.
          Phil
          #75495
          michael cole
            @michaelcole91146
            Hi Ed
            I use the same collect chuck. The end of the cutter is ment to be supported by the point in the chuck body. What i normally do is screw in cutter is threaded end is just short of coming through the threads in collect. Insert collect in body so your Edge A is as inserted as far as it can. tighten up nut hand tight give the cutter a final turn then tighten nut with wrench. Does not have to be very very tight. The grub screw is to stop the shoulders on the collect rotating..
            #75497
            Steambuff
              @steambuff
              I have the same collet system.. it’s a Quick Release Collet, I got mine from Axminster in the UK.
              It will only work with screw shanked milling cutters … Axminster also sell these. (I have yet to find another UK source at a reasonable price)
              I was told that you screw the cutter into the collet a few turns and then insert into the body and tighen up the body nut by hand, then finish screwing the cutter in and then pinch up the body with the spanner supplied. (If you screw the cutter all the way in first, you won’t be able to tighten it in the body)
              Ed Duffner
                @edduffner79357
                Phil, Mike and Dave,
                Many thanks for your replies and help, I understand now . I bought milling cutters with a plain shank. I misread the info on the Warco wbsite about the chuck being interchangeable, which just means that it’s possible to use imperial or metric collets in the same chuck.
                Ed.
                #75507
                Ian S C
                  @iansc
                  I made a holder for plain shank cutters that fits in a 3/4″ collet in my chuck. It consists of a bit of steel (from the junk box) turned to 3/4″ dia and screw cut and center drilled at one end, then turned around in the chuck and drilled to fit the shank of the cutter, the cutter has a flat gound on the side, so a hole was drilled in the side of the holder to correspond with the flat, thiswas tapped 1/4″ UNF. I can also fit a HSS countersink in it. Itr was made to cover an emergecy when I did’nt have a cutter with a screw shank. Theres usually a way of doing these things if you have to. Ian S C
                  #75518
                  David Littlewood
                    @davidlittlewood51847
                    Posted by Steambuff on 27/09/2011 23:29:39:
                    Tracy Tools sell sets of screwed shank milling cutters at quite low prices. They are very readily available, though normally not as cheap.
                    David
                    #75519
                    Steambuff
                      @steambuff
                      Many Thanks David … I’ll take a look
                      #75542
                      Ian S C
                        @iansc
                        A threaded extention, a size larger in dia could be silver soldered on to the plain shank in a similar way to the one that I made held together with a grub screw, just an idea if you must use that collet chuck. Practical??? Ian S C
                        #75546
                        Steambuff
                          @steambuff
                          Thats an idea …. or even tap the ends … oouch !!!
                          I prefer that collet chuck as I don’t have to keep removing the taper & drawbar when I want to change cutters (i.e from 6mm to 10mm to 16mm etc)
                          Never have liked hitting the end of the drawbar with a hammer. (Yes I have a small Sieg Mill)
                          Ed Duffner
                            @edduffner79357
                            Thank you guys for the great ideas.
                            I did have an idea of making a cutter extension, threaded at one end, with a boss on the other. I’d grind a flat on the end of the cutter’s plain shank which would be secured by a grub screw or two through the side of the boss.
                            At the moment though I’m very much a novice with machine tools and a few other skills e.g. silver soldering. Until I build up my skill set I’ll err on the side of safety and not try to make an adaptor, I’d always be thinking… is it going to hold? or, will it break? . I also don’t have a lathe just yet (a future acquisition).
                            Thanks again,
                            Ed.
                            PS. I have now ordered a 2MT ER25 collet chuck and collets which takes threaded or plain shank cutters.
                            #75556
                            NJH
                              @njh
                              Hi Ed
                              Posted by Ed Duffner on 29/09/2011 17:56:52:
                              This is just what I did to hold those mini – cutters (less than 1/4″ and come with a flat on the shank) in my Posilock chuck.
                              It works well but you must be sure that the shank of the holder and the hole for the cutter are concentric.
                              Norman
                              Edited By NJH on 29/09/2011 19:04:30
                              #75557
                              Tomfilery
                                @tomfilery
                                Steambuff makes an interesting point re hitting the drawbar with a hammer.
                                To avoid doing this on my Axminster MicroMill, I drilled the top part of the mill spindle (which is soft, unlike the morse taper part) using my pistol drill and tapped it M12. This allows a short bar to be inserted (obviously after the long one has been removed) and an M12 bolt screwed down against the bar, forcing the chuck out of the taper – saving hammering which always feels likely to damage the machine.
                                Regards Tom
                                #75578
                                Ian S C
                                  @iansc
                                  I did tap a thread onthe end of the shank of a 1/4″ drill, and put a center hole in it, then resharpend it to work as an end mill. With a drill you can do this as the shank is not hardened, but an end mill is hard all over. Ian S C
                                  #75581
                                  Geoff Theasby
                                    @geofftheasby
                                    My Warco milling machine recommends the use of a rubber hammer to help extract milling cutters and collets from the taper.
                                    I haven’t bought one yet, so I don’t know how effective one would be, but perhaps you shouldn’t screw down the drawbar too much either.
                                    Geoff
                                    #75682
                                    Ed Duffner
                                      @edduffner79357
                                      Hi Geoff,
                                      I use(d) a rubber mallet on my WM-16 and find that I cannot loosen the drawbar with it even with moderately heavy blows and not having the drawbar overtightened in the first place. I may switch to an aluminim dolly and regular hammer or a nylon hammer.
                                      Ed.
                                      #75814
                                      David Littlewood
                                        My Emco FB2 mill has an external thread on the upper end of the spindle. The drawbar is a very long hex socket capscrew; to remove, there is a threaded cap (with a hole in the end big enough for an Allen key) which screws on the external thread, then with a big Allen key in the drawbar and a spanner on the flats on the cap, you can force the drawbar up against the cap, which pushes out the 2MT tooling.
                                        One problem is that half the tooling you buy has an M10 thread, the other is 3/8″ BSW. I got overt this by making a 3/8″ BSW drawbar, with a hole in the upper end, into which I Loctited a turned-down M10 capscrew. Rather to my amazement and gratification, this has survived about 20 years of use.
                                        David
                                        Edited By David Littlewood on 04/10/2011 18:03:59
                                        #75820
                                        Mark P.
                                          @markp
                                          Posted by Ed Duffner on 02/10/2011 01:26:42:
                                          Hi Geoff,
                                          Ed.
                                          Hi Ed,I have a WM16 mill,I use the self-ejecting method ie.wind the drawbar out of the chuck / collet against the drawbar retaining nut.
                                          regards Pailo.
                                          #75867
                                          Ed Duffner
                                            @edduffner79357
                                            Hi Pailo,
                                            Many thanks for the tip, I will give it a try.
                                            Ed.
