colchester student 1800 apron no drive
Home › Forums › Beginners questions › colchester student 1800 apron no drive
  • #370222
    terryjwalker1
      @terryjwalker1
      hi
      I have problem on my lathe in that when automatic feeds are selecting for facing/sliding I get no response.
      I have traced problem to pinion shaft that should be driven by the long shaft that is below lead screw which I will call the sliding shaft. unfortunately although drawing I have in manual shows exploded view of apron it does not show the rear of the apron or this pinion shaft which sits in the apron casting.
      the sliding shaft which turns with no problem have a slot running nearly its whole length & this go through the pinion shaft in question & I conclude that from this slot should drive the pinion shaft by means of a key or such.
      However on inspection of the hole through the pinion shaft there appears to be nothing for it to be driven by.
      So I was wondering if anyone have any experience with this model & could provide some guidance.
      #9315
      terryjwalker1
        @terryjwalker1
        #370270
        Howard Lewis
          @howardlewis46836
          Don't know your lathe but suspect that there is a failed shear pin in the drive to the power shaft, near to where it is is coupled to the Norton gear box.
          If the Feedshaft (when selected) rotates under power, then the problem lies within the Saddle.
          If the Leadscrew (when selected) does not turn under power, then the problem lies in the drive INTO the gearbox.
          If drive to the Leadscrew is selected, it is likely that the drive to the Feedshaft is disconnected. This is to prevent conflict between the two feed modes of imparting movement to the Saddle.
          Rally stupid question: you have selected one of the forward or reverse positions for the feed selection?
          My lathe allows the gearbox to be: Rotated in the same direction as the Mandrel : Neutral (Disengaged) : or Rotate in the opposite direction to the Mandrel. Might be worth checking!
          Suggest that you start tracing the drive from the gear on the back of the Mandrel, until you find a failed key / keyway / gear lacking some teeth / failed shear pin, When you find something that no longer rotates when the mandrel is rotating, that is likely to be the problem area.
          There should be a key in the worm within the Saddle that engages with the Feedshaft to power the Saddle for facing and Sliding.
          Howard.
          Edited By Howard Lewis on 03/09/2018 17:58:40
          #370272
          Phil Whitley
            @philwhitley94135
            can you post some pics of where the shaft goes through the saddle? sounds like either the worm, key, or both are missing
            Edited By Phil Whitley on 03/09/2018 18:10:11
            #370280
            Mike Poole
              @mikepoole82104
              Has the feed worked since you have owned the lathe or has it never worked? Are you fully conversant with the controls for the feed?
              #372164
              Howard Lewis
                @howardlewis46836
                So have you found the source of the problem? And more importantly, solved it?
                Put us out of our misery!
