Cleaning cast iron wheel spokes
Home Forums Beginners questions Cleaning cast iron wheel spokes
  • #102110
    Phil H 1
      @philh1
      I need to clean the spokes of some small cast iron wheels (2" diameter) for a 3 1/2" locomotive. Any tips out there to get it done quickly and efficiently because I have worn out one round needle file and gone through two Dremel, aluminuim oxide grinding points for 1 wheel out of 10. Oh – the first wheel isn't finished yet!!
      PhilH
      #6409
      Phil H 1
        @philh1
        #102111
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Diamond files . Not little needle files but more small engineers file sizes . ARC have a good range .
          http://www.arceurotrade.co.uk
          Regards ,
          Michael Williams .
          #102123
          Sub Mandrel
            @submandrel
            Spokes are thin and can get slightly chilled and be very hard on the surface. I've used diamond-studded burrs in a mini tool to clean up flywheel catsings, which is essetuially the same task.
            Wear a face mask, or you will be blowing black bogies for 24 hours afterwards.
            Phil H 1
              @philh1
              Cheers guys.
              PhilH
              #102489
              Phil H 1
                @philh1
                Received a set of diamond burrs (diamond files are also on their way) and if the quick trial is anything to go by – they will sort the wheels out no problem. Thanks guys.
                PhilH
