Clarke drill press
Clarke drill press
Home › Forums › General Questions › Clarke drill press
  • #25431
    Harry Wilkes
      @harrywilkes58467
      #311409
      Harry Wilkes
        @harrywilkes58467
        I have a Clarke drill press Clarke CDP5DD for what I paid for it, it's served me well, however I need to replace the motor but I cannot find what the motor frame size is ! Would anyone know or any advice on how to establish the frame size ?
        Cheers
        H
        #311418
        not done it yet
          @notdoneityet
          Have you removed said motor and compared foot dimensions with a list like on engineeringtoolboxdotcom?
          #311444
            When I was looking for a motor once, I discovered it would have been cheaper to buy one of those pillar drills, remove the motor and throw the bits in the scrap bin.
            Prices have risen since, but it may be cheapest to replace the whole thing.
            Compare:
            Drill press at £80
            Slightly more powerful motor at £83
            <edit> if it hasn't burnt out, you probably only need to replace the start/run cap[acitor under a shroud on the side of the motor. Bargains! Much cheapness!
            Edited By Neil Wyatt on 11/08/2017 09:14:43
            #311445
            martin perman 1
              @martinperman1
              Harry,
              Go to this link https://www.machinemart.co.uk/ on the bottom right of the screen is "expert advice and Parts and service support" I've used it and found the response very helpful.
              Martin P
              #311450
              larry Phelan
                @larryphelan54019
                Agree with Neil ! Check out the capacitor first. Electric motors seem to go on for ever,I have some still running well after 50 years of workshop use. Capacitors are cheap.
                #311457
                Ian S C
                  @iansc
                  We've just retired one(still going strong) on the blower on the church pipe organ, made in 1917.
                  Ian S C
                  #311479
                  Harry Wilkes
                    @harrywilkes58467
                    Thanks for all replies
                    Not Done It Yet Intend to remove motor asap but just had minor surgery on left hand for carpal tunnel sad
                    Neil Same thought had crossed my mind
                    Martin Have seen the link so after your comment will give it a go
                    Thanks H
                    #311533
                    Grizzly bear
                      @grizzlybear
                      Metalworker Drill press, capacitor failed. Got one from RS Components, approx. £6 post free,
                      The new capacitor wouldn't fit inside the box, so strapped it to the motor. Perfect!
                      Regards, Bear..
                      #311647
                      Harry Wilkes
                        @harrywilkes58467
                        Single handed 'pun intended' had a closer look a the motor it looks like it's a special the mounting bracket is spot welded to the motor case and the shaft has been turned down for 0.625 to 14mm ! A quick check on the website 'not done it yet' suggested put's the motor at frame 56, I was looking to uprate the motor but as Neil pointed out a motor is nearly the cost of a new drill press so for now when hand allows I think I'll look at changing the bearings.
                        H
                        #311665
                          @mike89748
                          I did just what Neil did when I wanted an electric motor. Cheaper by some considerable margin than buying just the motor, and I got a no-volt switch and a cheap but surprisingly accurate chuck into the bargain. I'm still trying to work out what to make out of the left-over bits.
