Posted by Howard Lewis on 04/10/2016 18:43:36:
Is there a reason why the idler cannot be fitted the other way round?
The tumbler reverse adaptation sounds interesting. Has anyone any details, please?
1. I dont think you can turn it around, as the motor pulley has a much small step on the back for this mode, and the idler is a simple smaller to larger graduation, so it would be more like Motor small, idler small, spindle large, idler large.
Theres a but and a big one, theres nothing to stop you making another idler that gives you a much slower speed, would be an interesting modification and please post it on here if you did. You'll need to figure out the ratios, and a traditional dial RPM gauge would be needed to test the theory, i found one but you could probably pick one up on ebay quite cheaply. Provided theres no drastic change in size you could get away with using the same belts too, they'd be cheap enough even if you did have to change them.
I have no need for this mod as i went down the VFD route, purely because of the super fast screw cutting problem.
The VFD is obviously quite an expensive mod and not for the faint of heart, but i'd reckon the skill to make another pulley from a foundry cast bar would make it quite the cheaper alternative! You wouldn't need to cover all the steps, simply one to the motor and another to the spindle should be sufficient.
If you wanted to go down the VFD route, go for a motor thats 1/4-1/2 HP greater than a single phase to account for the loss in torque on lower speed settings. Not official advice there but probably worth telling.
2.The tumbler reverse mod is a mod i haven't done, but intend to, from what i know it's simply a case of adding an additional gear to the train to change the direction, so long as it's a simple train it should cast no bearing on the final resulting ratio. An additional swing banjo plate is probably the easiest way to go about this.
Michael Walters
Edited By Michael Walters on 04/10/2016 19:50:28
