Reading the Dials is good for beginners to learn whats going on, but it soon becomes a chore, i would opt for making some fittings for digital calipers, the cheaper ones, see how that is, i eventually went the whole hog and fitted glass scales and a DRO unit, thats alot more expensive though, but definitely worth it.
Another point of interest is the tailstock unit, whilst sturdy and adjustable, its length is a little short for regular work and you find yourself struggling to reach over the width of the cross slide. This means you're constantly winding back and forth to get up and down the table and reach the headstock, it's a chore without a rack and pinion feed. (I will touch on that in a minute)
So one way to get around it is to use a MT extension socket, it works fine, but can be a little wobbly when it's fully wound out of the unit, so i bought a 2" square piece of T6 aluminium, and extended the tailstock housing to support the socket. I did this because a casting was beyond me and a piece of steel would've been hard going to bore out a 6" long 38mm bore, so i opted for the tempered aluminium for ease of machining.
Bear in mind, that i have had a bad run of "failed mods", ones that i did my best attempt at and could not find a way to make them work with the machine. This included a rack and pinion feed, whilst i managed to mount a rack, there is hardly any room for a half nut mechanism, this meant i had to opt for a design which "wound in" to the feed screw, it wasn't great and the engagement was sketchy.
The dovetailed table makes a free moving table an issue, the gibs are very sensitive for decent movement. If you look at any of the major industrial machines, none of them use a dovetailed bed anymore and opt for a polygon styled rails, that the saddle sits on, it's much better at holding it fast without any sloppy movement, the sloppy movement makes for a terrible finish and would recommend sticking with what it was intended for, a permanently fixed leadscrew nut.
I've also tried a Ram style tail stock, it isn't a great idea either because of the same reasons, the ram isn't great for harder materials and without a feed screw makes for ropey movement.
There is scope for new avenues to be explored yet; Improving the fit of the changewheels, the shafts they sit on are unsupported from one side, and under load they can slip off the circlip tether.
50mm of movement is a little thin, so you could try making a new left hand M12 feed screw for the tail stock, and make it 75mm or 100mm. Stepper or DC motor feeds could also be tried. I can advise you on this if you need help. Go for 24v motors not 12v they aren't beefy enough, for a starters.
So heres hoping i can make good of some of my mistakes and guide you. My machine isn't permanently damaged by them because i always follow the rule don't do what you can't undo.
I'm glad i gave it a go, but ultimately i'm happy with the way it performs, it's paid for itself for sure and an old reliable friend indeed.
Michael W
Michael W
Edited By Michael Walters on 11/08/2016 13:44:17
Edited By Michael Walters on 11/08/2016 13:46:30
