CL500 servicing and information
Home › Forums › Introduce Yourself – New members start here! › CL500 servicing and information
  • #763822
    davehutchings
      @davehutchings
      Good morning,
      Thankyou for letting me join the group.
      I have just purchased a clarke CL500 lathe with drill/mill head. I will be servicing it before I use.
      My question are
      What oil do you use in the gearbox.
      Does anyone have a picture showing the belts under the end cover.
      Where is a good place to get a manual and spares.
      Thankyou
      Robert Butler
        @robertbutler92161
        If you go to the Chester Hobbystore website you can download a manual for a similar machine.
        Robert
        #763847
          You should find a manual cunningly concealed under the filename
          CL430_Metal_Lathe_REV_3.pdf
          Paste that filename  into a Google search, and witness the magic of t’internet in action.
          Howard Lewis
            @howardlewis46836
            An operator manual for the CL500M is available on line.
            And a Spare parts listing also.
            The CL430 is the bare lathe version.
            There have been posting on the Forum by other CL500 owners; might be worth looking for them.
            If you can’t find them, send me a PM with your E mail address, and I’ll send them over.
            #764195
            Howard Lewis
              @howardlewis46836
              The Operator manual merely says “drops of oil to…..” but does not specify the oil.
              If you are talking gearbox, it could be argued that you should use SAE90 gear oil.
              I use ordinary motor oil on my lathe and milli/drill, (Not Clarke or similar machines) without any obvious problems, over the last 21 years; but maybe i don’t load them too heavily. (I did spray some heavy duty gear grease onto the changewheels; Gets everywhere!)
              HTH
              #764200
                On Howard Lewis Said:
                An operator manual for the CL500M is available on line.[…]
                Looks like we’re on the same page this time, Howard
                Howard Lewis
                  @howardlewis46836
                  Michael,
                  That is good  As always, we are trying to help.
                  #764216
                  Bazyle
                    @bazyle
                    If you are in a large enough town to have industrial support you might find a source of machine oil. Else most people just use motor oil and there are special oils available from some motor factors for ‘vintage’ cars that have fewer additives. Some clubs have a supply of machine oil bought in bulk and sold to club members.
                    Some of the well known ME suppliers provide ‘way oil’ for slideways in suitable small quantities.
                    Don’t use grease or thick oil like EP90 unless the manufacturer very specifically requires it. On Changewheels use plain oil, not chain oil or grease because you actually want it to drip off, taking with it the dust and dirt that inevitably heads for these gears.
                    If you lathe has an enclosed spindle gearbox ie ‘gear head’ type and if it also has a pump use automatic transmission oil because it needs to be thin enough to be pumped, but if no pump use normal oil.
                    Lots of people get keen on hydraulic oil. Note the name. It is intended to be a non rusting substitute for water for hydraulic rams that can be pumped easily not to lubricate things.
                    If the manual recommends a specific supplier or oil bear in mind that is only because it was in the last manual they are copying and that was only recommended 30 odd years ago because the sales rep (before internet spoiled the freebies) took the drawing office manager out to lunch.
