chuck removal from speed reducer
Home › Forums › Manual machine tools › chuck removal from speed reducer
  • #517415
    sparky mike
      @sparkymike
      I have a Mason Master drill speed reducer and I wish to remove the chuck, a Jacobs Multicraft M6CG61. Having a problem shifting it. Are these screwed on or tapered ?
      Mike.
      #14126
      sparky mike
        @sparkymike
        #517417
        John Rudd
          @johnrudd16576
          Screwed on…..
          I currently have one disassembled…
          That is how I know.
          Edited By John Rudd on 04/01/2021 15:11:15
          #517418
          sparky mike
            @sparkymike
            Thanks John,
            Thought it might be but was not sure.
            How did you remove it ?
            Mike..
            #517422
            Brian Morehen
              @brianmorehen85290
              Close the chuck jaws up Fit the chuck key as if you where using some to tighten hold the wheel and give the chuck key a sharp tap job done chuck loosened.
              Regards Bee M
              #517442
              sparky mike
                @sparkymike
                It is now removed. Thanks for info above. A chuck key did not work, but a good sized allen key tightened in the chuck jaws and then a good hit on that did work. 3/8 UNF thread.
                I can now turn up a tapered mandrel with that size thread on other end to fit the small lathe I am restoring.
                Mike.
                #517445
                Howard Lewis
                  @howardlewis46836
                  Thanks for telling us that you have succeeded, and what thread to expect!
