Chinese Spot Drills
Chinese Spot Drills
Home › Forums › General Questions › Chinese Spot Drills
  • #303147
    Colin Whittaker
      @colinwhittaker20544
      It's only cost me a few dollars so it's no big deal …
      I decided to buy some spot drills for use in making accurately located holes in brass for a clock. The set of Chinese bits that arrived from AliExpress do not come to a conical point as I would expect. From one side the bit does come to a point but when rotated 90 degrees there is now a large flat profile that doesn't look as though it will deliver the wanted hole precision.
      Who's confused about what a spotting drill should do/look like? Me and/or the Chinese supplier?
      Thanks, Colin
      #25311
      Colin Whittaker
        What kind of tip facet should I expect?
        #303149
          All mine have a straight bit between the two ends much like you get on a twist drill, depending on make the size of this does vary.
          #303150
            On the left is an unbranded Chinese one (actually it may be Interstate) on the right a branded keo one that I got from MSC and that is the make I buy now as they cut better. Keo one probably cost more than a whole set from Aliexpress but if you want precision you need to buy decent things.
            #303167
            John Flack
              @johnflack59079
              I have in the past purchased c/drills from Drill Services these range from O to 4/O the smallest having a tip of 0.010". I paid about a fiver then,but being double ended halves the cost. No ides how this compares with info above
              Colin Whittaker
                Sounds like I do have the real thing.
                Thanks for the intelligent answers to my stupid question.
                I guess I'd better give my supplier some positive feedback.
                Cheers, Colin
                #303182
                ChrisB
                  @chrisb35596
                  The Dormer stub drills I have all end up with a pointed tip with almost no web. Compared to a stub drill a normal twist drill has a much larger web.
                  #303184
                    @mike89748
                    I've always used centre drills rather than spot drills. When both ends are no longer capable of being sharpened, you are left with a useful cylindrical bit of HSS which can be ground into other tools. Yes, I am stingy! My chart lists 12 drills, from sizes 00 to 10 (0.125 to 1 inch, although sizes 0 to 4 will perform most tasks in my workshop.
                    #303257
                    I.M. OUTAHERE
                      @i-m-outahere
                      I have a nice carbide spotting drill , split point geometry , well that was until i dropped it on the concrete floor chipping the point 😭 .
                      While i'm here and as i will eventually get around to fixing that spotting drill i am interested in everyones thoughts as to the type of grind i put on it with my T&C .
                      Split point ?
                      Four facet ?
                      Ian.
                      #303453
                        Expect an article on web thinning in the next MEW.
                        As far as I can see Jason's better drill has the web thinned, perhaps the other drill could be ground to match.
                        Spotting drills are a use for broken jobber's drills, as long as they haven't bent.
                          Keo site says their spot drills have a constant thickness thin web that does not require web thinning if sharpendsmiley See page 18 of cataloge
                          Edited By JasonB on 20/06/2017 19:55:55
