Chinese diesel heater
Home › Forums › The Tea Room › Chinese diesel heater
Viewing 25 posts - 1 through 25 (of 145 total)
  • #624408
    Steviegtr
      @steviegtr
      Hi all. Well this week I have been spending a lot of time in my workshop building the Hemingway large bore steady rest.
      So it has cost roughly £8 per day in the ever rising electricity. I have been considering for some time to fit the Chinese made diesel heater to the workshop of which a lot of youtube guys have done. Anyone tried them. It seems they are around 5kw flat out down to around 1kw on 1hz pump cycle. Doing a bit of searching there are quite a few vids of testing their usage of diesel.
      Running Kerosine or red diesel it seems on low setting they cost around 12p per hour to run. In my Insulated workshop my heater runs (2kw) flat out for about an hr before hitting the thermostat setting of around 19-20 C. Then on & off as the temperature alters. Brother in law is about to fit one in his latest camper build. But it seems more & more are using them in the garage / workshop.
      Any thoughts or experience of doing this addition. I have a few sources of 12v dc power supplies that will handle the electric side of things. They are around £100/£120 on ebay. Direct from China a little over £50 delivered but 1 month delivery.
      Steve.
      #37067
      Steviegtr
        @steviegtr
        Do I buy one ,, workshop
        #624410
        Jon Lawes
          @jonlawes51698
          I have one. I have the suitcase type mounted on the wall with the exhaust leading to a hole in the wall (brick double thickness). I use ducting to take the air to two different points in the workshop for better air mixing.
          As the exhaust comes from the bottom I had to make a shelf type arrangement with a hole in the bottom to allow it to pass through. I use two carbon monoxide detectors as a failsafe. It's very efficient and cost effective in my opinion. Primarily my concern is not to reduce the cost as to take the heating of my workshop off of the electric bill so its my responsibility, not the family's.
          For the power I use an old car battery on a trickle charger.
          Not everyone has the same level of success; I've heard of many people getting faulty ones. However mine was under £100 at the time so felt like it was worth the risk. Also you can change individual components if they fail, and a fault code tells you which one is at fault apparently. If warms my medium sized workshop from zero to 18 degrees in about half an hour, but if you get the ducting right the average ambient doesn't matter as you are getting a majority of the heat from the ducts in your face….
          #624418
          Steviegtr
            @steviegtr
            Thanks for that Jon. Inspiring to know someone who has done it.
            Steve.
            #624421
            Ady1
              @ady1
              If I needed one I would buy it ASAP before they ban them
              The way domestic prices are going it won't be long before large numbers of people start using these solutions to save money
              Your first 30 litres each quarter are free since there's no standing charge
              Edited By Ady1 on 11/12/2022 01:43:00
              #624432
                Steve, see the comments about them in the recent Vevor thread
                #624444
                not done it yet
                  @notdoneityet
                  Posted by Steviegtr on 11/12/2022 00:22:30:
                  Steve.
                  I have done it, too.
                  Remember, there is no such thing as an 8kW cheap chinese diesel air heater, even though many try to argue there is! Even the 5kW versions do not deliver 5kW.
                  Perhaps you should make a youtube video of your installation so we can comment on it? (this in reference to one of your earlier posts, on another thread)
                  #624457
                    Posted by Steviegtr on 10/12/2022 22:58:00:
                    Running Kerosine or red diesel it seems on low setting they cost around 12p per hour to run. In my Insulated workshop my heater runs (2kw) flat out for about an hr before hitting the thermostat setting of around 19-20 C. Then on & off as the temperature alters. …
                    Steve.
                    It's possible to work this out , basically comparing the cost of an oil heater with the cost of electric.
                    Inputs.
                    • Diesel costs £1.83 per litre (Heating Oil £0.79)
                    • Burning a litre of oil produces about 9.5kWh
                    • Electricity is £0.28 per kWh, but might rise to £0.48
                    Before making the comparison, it's important to establish accurately how much electricity is being used. £8 per day is suspiciously high. How was it measured? I think it may be an over-estimate.
                    Assuming £8 is correct, at 0.28 per unit that's 28.6kWh, equivalent to 3 litres of diesel costing £5.49. Heating oil would cost £2.37, but this assumes a diesel heater can burn heating oil safely and efficiently. Probably OK but I'd be surprised if a youtuber had tested it: a heater run on the wrong oil might spew Carbon Monoxide and unburnt hydrocarbons whilst wasting money.
                    A running cost of 12p/hour means a diesel oil heater is actually outputting 0.6kw, not '5kw flat out'. 5kWh would cost about £1, not 12p.
                    A disadvantage of oil heating is that a good percentage of the heat goes up the chimney, whereas electricity keeps it all in the room. How much heat is wasted by an oil heater depends on how the exhaust is arranged. A pipe running around the workshop before leaving the building will do better than one that exits immediately, but long pipes cause other problems.
                    Nonetheless, oil will cheaper than electricity in the long run. But it's important to understand what the long run is. In order to save money by burning oil, it's necessary to spend money first. The heater and it's power supply have to be bought and installed. The time and money are a dead-loss until the investment has been recovered. I'd guess about £200, which, if Steve's £8 is typical, means he has to spend 25 cold-days in the workshop before oil becomes cheaper. Thereafter, money is slowly saved, but only if the heating is used, and long cold-spells are unusual in the UK.
                    Northerners tell us they're tough compared with Southerners. Heating a workshop to 20° is too hot for this West Country softie! I run my house heating 5 hours a day at 18°C and don't heat the workshop at all. I prefer to work physically at 12 to 15°C, and usually the lights and machines are enough to take the chill off. But a huge amount depends on how well the workshop is insulated. Snow outside, and mine is at 10°C, not so bad if I dress warmly. Fortunately, I don't have to work in my garden shed – it's below zero.
                    The easiest way to save money is to turn the thermostat down! Try 18 rather than 20°C
                    noel shelley
                      @noelshelley55608
                      Add my name to the list of those that have used one ! About £120 with self contained fuel tank, run from an old 12v battery and charger. BE CAREFUL when fitting the exhaust up as it gets VERY hot. A neat unit that has worked well so far, was installed in a 20'container 18months ago..There are many combinations on offer, some with an exhaust silencer, extra ducting, Etc Noel.
                      #624468
                      Jon Lawes
                        @jonlawes51698
                        My exhaust runs a while around the workshop to add radiant heat. I don't have a silencer but the distance helps keep the disturbance to my neighbours down. I discarded the cheap nasty hose clips supplied with it and used better quality ones. At one point I had to take the exhaust near some domestic wiring so I made a top hat bracket to keep it very well clear.
                        Two CO detectors might sound like overkill but I chose different brands as I figured they might have different thresholds, and different battery lives. One started going off when I was running my stationary engine outside the door the other day so they appear to work!
                        As mentioned mine was primarily used to seperate the bill from the household bills, it may or may not be any different in price. The exhaust fumes by the time they leave my long exhaust pipe (which has been made to minimise the use of tight radii) as cooler than the air from a hand dryer. The exhaust pipe as it leaves the unit has turned blue with the heat.
                        #624472
                        Old School
                          @oldschool
                          I have one in my workshop it came from Vevor so far so good, it has been run on heating oil from day one as our central heating is oil fired.
                          #624474
                          John Doe 2
                            @johndoe2
                            • [quote] Electricity is £0.28 per kWh, but might rise to £0.48 [quote]
                            That sounds like a good price ! We are with Octopus and the charge for electricity is £0.3337 per kWh, plus a daily standing charge of £0.475. (That is 100% from renewable sources, so maybe it costs a bit more).
                            Are there any issues with fossil burning heaters producing moisture laden warm air, or is the burning flame completely separated from the workshop?
                            #624477
                            Robert Atkinson 2
                              @robertatkinson2
                              I wonder what your insurance would say if one of these burnt your workshop, or worse, house down? The heaters are clearly not designed for this application. They do not seem to have any proper approvals either. A random one on ebay ( https://www.ebay.co.uk/itm/374189752217? ) proudly displays a UKCA certificate. However as it is a car/truck part UKCA does not apply, it should be ECE "E" marked. Even if it was UKCA the harmonised standards on the certificate don't apply to the unit. For example, BS EN 6100-3-2 is conducted harmonics for AC mains powered equipment…
                              The precaution of two independent CO monitors is very wise. Putting the fuel tank outside, with metal pipework and a overheat / fire shut-off (spring loaded valve held open by low temperature melting point link would be good too.
                              Robert G8RPI.
                              #624479
                              mgnbuk
                                @mgnbuk
                                Another happy user of a Chinese 5KW heater for the garage here. I use a 12V 20A power supply to run mine rather than a battery / charger – probably overkill, as I understand the heaters draw around 10A while the glow pin is operating & around an amp when the glow pin switches off, but a 10A PSU at the time wasn't much cheaper than the unit I bought. I went for a component system & built an angle iron frame to hold it and the PSU and fuel it from a 25 litre oil drum, but if I were to do the job again I would go for one of the free-standing cased units with an integral fuel tank that are now available.
                                A local filling station has a "gas oil" pump which, last time I filled a Jerry can, was around 2/3rds the price of "road" diesel. These heaters will also run on paraffin (some suggestions are that they have less carbon build-up internally when run on paraffin), but I don't have a local supplier of bulk paraffin any more. Contrary to SoD's assertion above, there are many YouTube videos of people experimenting with various fuels for these heaters & they appear to operate on virtually any oil, though (as I understand the current situation) it is illegal to burn anything other than an "approved fuel", which rules out legally using used engine oil as demonstrated by some.
                                0.1 litres per hour per Kw output seems to be the norm for these heaters (around 0.5 litres per hour for a 5KW unit running flat out).
                                My exhaust is routed close to the (pressed concrete, mock stone, block) garage wall & exits through a hole drilled through the wall. Noise from the (single silencer) outlet is a low purr when running flat out, with no smoke or smell. I have a glass fibre exhaust wrap to insulate the exhaust run inside the garage (on the "to do" list) just in case anything flammable should fall on the pipe un-noticed – the exhausts, as stated above, run very hot. The heaters are quite noisy on the inside of the garage , though – you can't move large amounts of air with a small-ish fan quietly – but I don't find it objectionably loud.
                                I also fitted one to my employer's camper van this year & both systems worked without problems "out of the box". So far the Chinese heater has proven more reliable than a 5KW Webasto unit fitted to a motorhome I once owned but, to be fair, the Webasto failure was largely due to an installation error by the motorhome builder. A Webasto unit is over 10 x the cost of the Chinese "clones" & didn't appear (when operating correctly) to be any better or more econonomical. I am toying with the idea of installing one in my current motorhome as a back-up the the installed gas heating system.
                                I doubt my installation would get my double garage workshop up to 20 degrees from the current "around 0", but it would get it comfortable after an hour or so, which my previous 2KW convection heater could not achieve.
                                Nigel B.
                                #624492
                                Chris Evans 6
                                  @chrisevans6
                                  For the last 9 years I have used an Eberspacher D5 heater in my garage (double garage full height of the house).
                                  A heath robinson installation done for me by a friend as payment for some machining work. Very good heater enough to take the chill off and be comfortable to work. The heater was second hand and runs from a 240 to 24 volt transformer. Air inlet and exhaust go through the 9" wall to outside and very frugal to run, I use regular diesel, red diesel or heating oil depending on what I can get hold of. Just payed £0,78 litre for heating oil, 50 litres will do two or three winters depending on weather and workshop activity. I believe the exhaust length is critticle for these heaters but that is only what I was told so not sure if true.
                                  #624496
                                  mike T
                                    @miket56243
                                    I have installed one of those cheap Chinese cloned diesel heater in my workshop. When it works, it is very warm and cosy.
                                    However, I have had no end of problems with the fuel pumps sticking and refusing to pump. I have tried three different ones, they run for a few days/ weeks then stick. Not found a reliable way to un-stick them.
                                    The problem may be that Chinese cloned products can come from any number of different factories. Some factories may get the details right while others may not.
                                    Your mileage may differ.
                                    Edited By mike T on 11/12/2022 12:19:05
                                    #624498
                                    Hopper
                                      @hopper
                                      Posted by SillyOldDuffer on 11/12/2022 09:56:56:
                                      Inputs.
                                      But does one kWh of electricity produce 1kWh of heat? Most heaters are not that efficient methinks. So to produce 1kWh of heat would take more than 1kWh of electrickery.
                                      Anyhow, I am off to sleep in my air-conditioned bedroom. It should be a nice cool 20C by now. 30 in the rest of the house at 10pm, with 75 per humidity it's getting a bit sweaty.
                                      #624499
                                      Alan Wood 4
                                        @alanwood4
                                        I have two write ups on my blog relating to my experiences installing and using one of these heaters.
                                        Heater install
                                        Heater Update
                                        Re pump sticking this may relate to using domestic heating oil rather than diesel fuel. Domestic heating oil has no lubricating oil content and therefore the impulse pump will fail. I use a 60/40 mix and have had no problems.
                                        Alan
                                        #624501
                                        George Jervis
                                          @georgejervis86082
                                          I have installed one into my workshop, I found its the best way to heat my workshop, I use a couple of larger tractor battery which is charged with a 210watt solar panel on the workshop roof and a cheap pwd inverter, I also have a 12volt 1000 watt to 230v inverter which I use to run my workshop lights or my lathe/mill lighting (led ones) (not my lathe and mill their 3 phase), and any thing else like cordless drill battery packs etc, their not used all at the same time but does help to keep the bills down for the home management
                                          George
                                          #624502
                                          George Jervis
                                            @georgejervis86082
                                            George
                                            #624504
                                            mike T
                                              @miket56243
                                              The pump sticking issues, I referred to, occure using regular pump diesel.
                                              It is well known that diesel can gum up in really cold weather. My heater always worked best in mild weather rather than in cold weather.
                                              #624512
                                              Alan Wood 4
                                                @alanwood4
                                                Mike T – it could be the diesel going soapy.
                                                My pump is mounted vertically as recommended and is well wrapped with insulation to try to minimise the ticking noise. I have not insulated the header tank even though the whole assembly is mounted outside albeit fully enclosed (see blog image). The enclosure is a double decked affair with the heater on the lower level. The residual heat from the heater therefore warms the inside of the enclosure with the header tank directly above the heater. The fuel and the pump therefore benefit from protection.
                                                #624523
                                                mike T
                                                  @miket56243
                                                  Hello Alan
                                                  I've seen your external installation. Very neat.
                                                  Could you please explain and expand on
                                                  " Mike T – it could be the diesel going soapy."
                                                  #624527
                                                  Chris Evans 6
                                                    @chrisevans6
                                                    Posted by Alan Wood 4 on 11/12/2022 13:06:06:
                                                    Re vertically mounted pump, on the Eberspacher the pump has to be at an angle to work. Mine is around 60 degrees and works with heating oil and diesel piped up from a floor mounted beer barrel.
                                                    #624529
                                                    File Handle
                                                      @filehandle
                                                      Posted by Jon Lawes on 11/12/2022 10:26:28:
                                                      Do you really mean that it is giving off IR radiation, or that it is heating by conduction and convection. Household radiators are wrongly named as the main heat from them occurs via conduction and convection.
                                                    • The topic ‘Chinese diesel heater’ is closed to new replies.
