Hi all, I bought a Chester DB8VS a couple of months ago 2nd hand, but not actually used. It's been fine but recently started to make a ticking/knocking noise. The noise speeds up with increasing speed, but after using the lathe for about 5/10 minutes completely disappears until the next cold start. I sent a video of this to Chester who told me that it's the motor or possibly the brushes. I took the brushes out which were fine but loose so I tightened them up, put it all back together and no more noise. Until last night…
On closer inspection I found that changing the belt tension changed the pitch of the noise. I then removed the belt completely and ran the motor and there's no noise, but also granted no load. It's leading me to think that it's the tensioner, although the bearings feel OK and there's no odd movement in it. I don't want to over tension the belt in order to get rid of the noise. I've ordered bearings for the tensioner as a starting point but I was wondering if anyone has had a similar issue and also, what kind of slack there should be in the belt under the correct tension?
Thanks
