Cheap pressure gauges.
Home › Forums › Locomotives › Cheap pressure gauges.
  • #204246
    Maurice Cox 1
      @mauricecox1
      Just been into The Plumb Centre. They have a special offer at the moment. Its a two inch diameter pressure gauge on an armoured hose. It reads to 160 psi. Also Bar and that metric one. £4.17 plus v.a.t! Looks quite robust. Good for boiler testing? I assume these offers are across all their stores . I was in the High Wycombe one.
      Maurice
      #1451
      Maurice Cox 1
        @mauricecox1
        #204719
        Swarf, Mostly!
          @swarfmostly
          Hi there, Maurice,
          I went to my nearest Plumb Centre branch (Horndean, Hampshire) today – they didn't know anything about a special offer on pressure gauges! All I was offered was a gauge with hose for £13-ish.
          The other end of the hose has a 3/4" BSP union nut made of plastic (similar to the end of a washing machine hose). Seems a bit on the big side for 'our' purposes!
          Best regards,
          Swarf, Mostly!
          #204817
          Ian S C
            @iansc
            Swarf, that just about sounds like one that I have, made to fit on a hose tap in the garden to check the water pressure, our pressure here ranges from very little, to quite a bit less.
            Ian S C
            #204820
              I got a lovely one from Machine Mart several years ago for setting the pressure of a car LPG regulator. Worked really well and I've since used it to test my own simple boilers (which are below the bar-litre limit).
            Home › Forums › Locomotives › Topics
