Changing apron oil – ? Flush out
Home › Forums › Workshop Techniques › Changing apron oil – ? Flush out
  • #15790
    capnahab
      @capnahab
      Apron crud
      #195775
      capnahab
        @capnahab
        I am doing an oil change on a DSG 17. When I undid the plug nothing came out .. – not a good sign. I penetrated the sediment at the bottom of the apron with a bit of wire and pretty thick gloop of congealed oil came out followed by the 2 pints of oil.
        It's pretty clean, not much metal and still clear tho thick. I have to replace it with 68 grade oil.
        Should I flush the rest of the gloop out or just leave it. And what with ?.
        #195777
        Phil Whitley
          @philwhitley94135
          If you can get a bent bit of wire in and scrape the gloop to loosen it from the bottom, then flush with diesel fuel, parrafin or white spirit, in that order of preferance, allow it to drain well, and refill, you shoiuld be good to go. My first lathe was a DS&G 13Z.
          Phil
          #195786
          capnahab
            @capnahab
            excellent, thanks Phil. I have even got some diesel.
            have sent you a message about the DSG.
          Home › Forums › Workshop Techniques › Topics
