Noel the gears with the 2 pins are NOT Drummond if they have 7/16 in. bore, Drummond are 5/8 in. and as Hopper has said Drummond gear will be 14dp and 14.5 deg.pa. Myford change gears are 20dp and 14.5 deg.pa, but the tumbler reverse gears on a Myford could well be 20 deg.pa, I know they are on some models.
The only lathe that I've seen on the lathes.co.uk website with 7/16 in. bore gears is the Exe, and I believe that that make used a 2 pin drive system as well.
Have you recently acquired these via EBay by any chance?
