Change-Wheel Mystery
Home › Forums › Manual machine tools › Change-Wheel Mystery
  • #174859
      The  little Jason lathe came with only the auto-traverse gearing
      • Driver on headstock spindle: 32
      • Compound Gear: 32/16
      • Compound Gear: 56/20
      • Driven Gear on leadscrew: 64
      • Leacdscrew tpi: 16
      This gives a traverse equivalent to 179.2 tpi.
      … Fair enough, I suppose; but why choose those counts?
      Now the plot thickens: it appears that the Cowells ME90 comes with the same numbers, except that they are all seperate gears, and it [now] has a metric leadscrew.
      Brian Perris was the original designer of both machines, so perhaps it just reflects his preference [or the gears he had in-stock at the time] … but I would be grateful if anyone could provide a logical reason
      Edited By Michael Gilligan on 05/01/2015 18:04:33
      Edited By Michael Gilligan on 05/01/2015 18:06:27
      #12403
        strange choice for auto-traverse …
        #174864
        Bazyle
          @bazyle
          They are all multiples of 8 (20 being a compromise for 40). Common change gear sets are either multiples of 5 or multiples of 8 with a few strays thown in. I suspect the full set for the ME90 filled in the gaps.
          A cunning salesman would have arranged that the supplied gears didn't quite give the most wanted threads pushing the user into an early purchase of a few more.
          #174865
            Posted by Bazyle on 05/01/2015 18:56:34:
            … (20 being a compromise for 40) …
            Aha !! … That's the 'logic' I had missed
            … I kept focussing on the factor of 5
            Thanks
              Brian Perris was apparently measured at exactly 5' 10.551" during a visit to the NPL. I think it's probably his little joke
              Seriously, why 56 rather than the more usual 57 (oft needed for 19tpi)?
              duncan webster 1
                @duncanwebster1
                Screwcutting 19tpi on a cowells sounds a bit optimistic to me, the chip width is 40 thou. Mie wouldn't do that, at the very least the chuck would not grip (perhaps I need another chuck, it's a lever scroll thing)
