Centec 2A riser block
Home › Forums › General Questions › Centec 2A riser block
Viewing 25 posts - 1 through 25 (of 32 total)
  • #423963
    Bill York
      @billyork72513
      Hi Guys and Dolls, I need information as to where I can get a riser block for my 2a or does any member have one the want to sell. Any help would be great. Thanks.
      #26772
      Bill York
        @billyork72513
        #423965
        Dave Halford
          @davehalford22513
          You may have to make it smiley
          (short one)
          #423966
          Bill York
            @billyork72513
            Have considered that, seem to remember some one on here saying the long version were made of aluminium, does that sound right,
            #423973
            Gary Wooding
              @garywooding25363
              I've made about 20+ blocks, mostly long ones, but 2 or 3 short ones. All were made of 6082T6 aluminium.
              If you're considering making one then I can let you have some of the working drawings I did. If you intend to do any horizontal milling then I strongly recommend making a long one because the VH is very heavy, and once fitted on a long block, it doesn't need to be removed for the change over.
              #423976
              Bill York
                @billyork72513
                Gary, that would be good, is there room on a 2a to cut a long one, alternatively how much would you charge to make one for me.
                #424023
                Gary Wooding
                  @garywooding25363
                  Sorry Bill, the Domestic Authority has forbidden me to make any more. frown
                  I still have the drawings though.
                  #424027
                  Simon Williams 3
                    @simonwilliams3
                    Gary – I would be very interested to see a copy of your drawings, and I have sent you a PM with details.
                    I have two Centec Automills – an "A" and a "B" – and the vertical head without the quill. This fits directly onto the Automill (A) but not the type B as the dovetail in the column is wider. I'm sure you knew that but others less familiar with the marque may wonder what the difference is.
                    I bought a lump of EN1A leaded a little while ago to make a riser/adaptor block – the job would be immensely easier with the drawings to hand.
                    Best rgds Simon
                    #424028
                    peak4
                      @peak4
                      I'd also be interested to see your drawings please.
                      I was hoping to order one from Tony at Lathes.co.uk but it doesn't look like he's going to commission any more.
                      Bill
                      #424029
                      Frank Gorse
                        @frankgorse
                        Bill,if you look up “centec raising block” on this site you’ll find a recent discussion about this. A 2b isn’t quite long enough to make the long block so the 2a certainly can’t and there’s no point in having the short block( unless you’re willing to give up the horizontal facility) because of the weight of the vert. head. Still trying to organise getting mine made,I’ll send you a pm tomorrow. Frank
                        #424031
                        Simon Williams 3
                          @simonwilliams3
                          Ooops – misinformation alert!
                          Sorry folks, Automills come as Mk1 and Mk2, not A.B.C etc.
                          My apologies.
                          Simon
                          #424033
                          Bill York
                            @billyork72513
                            Gary, thanks I would be grateful for the drawings,will you post them on here or send to my mail.
                            #424034
                            Bill York
                              @billyork72513
                              Frank, thanks, any info I can get will be helpful.
                              #424134
                              Gary Wooding
                                @garywooding25363
                                The drawings I created for making the blocks were intended for my own use only, but I've had so many requests for them that I've put them in a PDF. They are not really of publishable quality but they are what I used, so they do the job. If you decide to redistribute them then please acknowledge their origin.
                                The PDF can be found **HERE**
                                Here are some photos of a few
                                Long block retracted
                                Long block extended
                                Long raising blocks
                                Short raising block
                                #424147
                                Frank Gorse
                                  @frankgorse
                                  Thanks for that Gary,very kind. Frank
                                  #424154
                                  peak4
                                    @peak4
                                    Thanks from me too.
                                    If I may ask, from where did you obtain the alloy bar?
                                    Thanks
                                    Bill
                                    Edited By peak4 on 14/08/2019 16:23:49
                                    #424159
                                    duncan webster 1
                                      @duncanwebster1
                                      I know a jobbing machine shop who could make a batch of these, but there are a couple of dimensions missing, ie overall height and length. I know the height doesn't really matter, but what has been found convenient? What are people willing to pay?
                                      #424161
                                      Brian H
                                        @brianh50089
                                        Many thanks for the PDF Gary, that's very helpful and very kind.
                                        #424163
                                        Bill York
                                          @billyork72513
                                          Yep thanks from me to Gary.
                                          #424164
                                          Bill York
                                            @billyork72513
                                            With the long one did you not find it somewhat forward heavy.
                                            #424168
                                            Frank Gorse
                                              @frankgorse
                                              Gary has given us the length as 457mm and heights as 114 or127 overall. I’d been assuming they were made from 100×100 which is easy to find but obviously not so ideal mechanically. Next problem for anyone thinking of batch production is the different sizes of dovetail-the overarm bracket on mine would be an extremely tight fit on the v.head,for example. Would it matter if the ‘female’ dovetails were cut a few thou on the large side and a thin gib strip made to take up any difference,we’re only clamping something in place after all,not like the dovetail s on the table. In fact,given that it’s made of aluminium,perhaps a strip of steel or brass would be a good thing.
                                              #424176
                                              not done it yet
                                                @notdoneityet
                                                Please point out any flaws in my thoughts.
                                                I think I would “fabricate” rather than machine in one piece.
                                                The only really important aligned part would be the bottom sliding bevel.
                                                The vertical head only needs alignment to maintain it perfectly perpendicular to the table in one direction (long travel tramming is achieved by adjusting the head. Minor shimming of a separate part is easily carried out once initially aligned.
                                                The belt drive can accommodate any very slight mis-alignment, but anything important would be obvious, so not an issue.
                                                The vertical head, when not in use does not need to slide to the rear of the riser. Only a short dovetail is needed.
                                                Unless the head is rotated to nearly horizontal, it cannot be moved back very far at all.
                                                A separate bottom dovetail requires substantial support – the mass of the riser should support the extra weight of the vertical head overhanging so needs to be substantial (not a skinny riser).
                                                The head is only held by the two holding lugs, so actually bears only on one side after tightening securely in position.
                                                This leads me to the conclusion that only a parallel block of aluminium actually needs to be used as a basis for the load bearing structure with both the top and bottom bevelled parts securely fixed to it (or possibly only one).
                                                My riser raises the head by 120mm, I think – I could measure it up if anyone is interested. It is not light, of course, even in aluminium.
                                                #424210
                                                Simon Williams 3
                                                  @simonwilliams3
                                                  Gary, good evening and thank you indeed for putting the pdf files of the dovetail dimensions up for us to see. Most helpful.
                                                  I've just got a tractor engine to rebuild and then maybe I can back to this project.
                                                  Best rgds Simon
                                                  #424220
                                                  not done it yet
                                                    @notdoneityet
                                                    I think mine on a 2B might well be one made by Gary but it has no ‘Centec’ labels attached.. Block was 90mm x 127mm x 456mm (shock horror – did he short change someone by a mm?smiley)
                                                    I think Gary has miscalculated the lift delivered in that he has subtracted both the top and bottom dovetails when it is only less the one – the male one – which reduces the lift from block original dims. The lift of mine is approx 116-117mm.
                                                    added:  aluminiumwarehouse.co.uk do square bar 114mm. Costs £145 – a bit expensive to shave off £35 quids worth of swarf!.  Makes adding separate dovetails, to get 110mm lift and shave off £15 quids worth of scrap from a 4” piece look almost worthwhile?  But adding in the cost of the dovetails will knock a hole in the savings for the ally.
                                                    A 3 1/2” block at £88 gets better and a 220mm block @ £42 (or £55 for a l4&rdquo seems tempting if you don’t mind lifting off the vertical head when going horizontal milling…
                                                    Delivery extra, of course.sad
                                                    Edited By not done it yet on 14/08/2019 21:26:47
                                                    #424238
                                                    Gary Wooding
                                                      @garywooding25363
                                                      I got the alloy bar from Richard Austin Alloys in Coventry.
                                                      No problems have been reported about the VH's weight on the raising bar when slid in the forward position.
                                                      I don't think it matters at all if the female dovetail was a little on the large side. There has to be clearance otherwise you can't slide. The fingers push the male dovetail sideways so there will be a gap on the finger side, but none on the other.
