Thanks also Neil.
A while ago I bought a set of nearly 40 TCT brazed 12mm shank tools, at package price close to £1 per piece. Good price, but I was not very impressed by turning results. Then on closer examination, i found out that the front and side faces variably and in many cases not at all finished, often completetey rough and unground with the cutting 'edge' unble to contact the work before the rough carbide body below.
After grinding the tool on a green grit wheel (quite a tough process!) the tools did cut well, but they did seem generally somewhat more fragile than expected – I was turning some stainless 304 at the time, and if the tool height was not fully correct, the tool tip frequently broke nearing the centre of the facing cut.
I also found that with a 9-piece set of TCT boring tools: again although the tools appeared to be ready ground, the front face was ground in many cases at such an angle that the body of the carbide fouled the work before the cutting edge could make contact, however one oriented the tool. Again, regrinding the tools made them usable.
I am inclined now more to use insert tooling. However I did find on using a holder with CCMT insert from one of respected suppliers on this site, that it was completely unsuitable for any sort of light cut, having a remakably round surface where I expected to find a cutting edge, such that there was no sharp edge to cut the work before the insert body contacted it! I assume it is intended for very high speed heavy work, such that the tool forces its way through semi-molten work surface – is that correct, and the alleged reason for not using insert tooling on small lathes? Certainly not suited to any light finishing cut.
The CCGT tips work well, and can be used on mild ferrous material (including interrupted cuts), but don't necessarily expect a very long tip life, but a useful one.
Martin
