Can you help identify this lathe compound slide?
Home › Forums › Manual machine tools › Can you help identify this lathe compound slide?
  • #616642
    AJAX
      @ajax
      This compound slide has joined my "it will be useful one day" collection. It has the feel and appearance of being a quality item, with a slick action, thrust bearings and adjustable gib strips. Curiously, it incorporates a small lever and secondary range of movement perpendicular to the feed screw. I'm not sure how that would be used.
      If anyone could enlighten me or even suggest a machine this belonged to I would be interested to hear from you.
      20221008-231805 20221008-224859
      #14674
      AJAX
        @ajax
        #617195
        john willman 1
          @johnwillman1
          I have a Karger DL1 lathe which has a similar topslide with the extra lever operated slide. Unfortunately the extra slide takes up so much room the only small tools can be used, and I have had to use an alternative one.
          #617197
          Bazyle
            @bazyle
            Built-in screwcutting tool retraction is a nice feature.
            #617305
            Phil Whitley
              @philwhitley94135
              From the colour (if original) Possibly Raglan?
              #617388
              john willman 1
                @johnwillman1
                Since most machinists turn the topslide to half the thread angle and so that the tool only cuts on one flank, having the retracting part at right angles is quite useless. I never found a use for it !
                #617391
                Hopper
                  @hopper
                  Posted by john willman 1 on 15/10/2022 12:17:11:
                  It should still retract the tool out beyond the OD to clear for reverse traverse, should it not? Then reset the retraction and then add the next depth of cut on the topslide dial?
                  Seems like it would be just about as easy to wind the cross slide dial. But perhaps the quicker action of the retractor allows you to cut closer to a shoulder or to screwcut at higher rpm, which is always very handy.
                  #617410
                  Ian P
                    @ianp
                    Do you mean you have a machine with the retracting function, but you never use it?
                    How do you know 'most machinists' set the topslide to half angle? I for one have never done that.
                    Ian P
                    #617419
                    ega
                      @ega
                      Posted by Ian P on 15/10/2022 15:04:01:…
                      Ian P
                      As with Guinness – try it, you might like it!
                      #617429
                      Tony Pratt 1
                        @tonypratt1
                        Proper use of a retracting top slide makes screw cutting a little less likely to go pear shaped.
                        Tony
                        #617449
                        AJAX
                          @ajax
                          Posted by Bazyle on 13/10/2022 22:03:47:
                          Thanks, I guess it could be used that way.
                          #617450
                          AJAX
                            @ajax
                            Posted by Phil Whitley on 14/10/2022 18:12:17:
                            It looks like original (chipped) paint to me.
