can i silver solder cast iron
Home › Forums › General Questions › can i silver solder cast iron
  • #343558
    Brett Hurt
      @bretthurt41827
      I work on old phonograps those old things you crank up. And on working on this one I broke a part and need too know if I can silver solder it back. And what do I need for this, I have never silver soldered?.
      #25843
      Brett Hurt
        @bretthurt41827
        #343560
          Yes. Even I can do it
          One approach is to heat bit red hot and let it gcool, this burns off surface carbon. Then flux, reheat and silver solder as normal.
          Keith Hale's book goes into some detail on teh subject.
          Alan Charleston
            @alancharleston78882
            Hi Brett,
            If you have a nice crisp break with the two bits fitting snugly together you might like to try gluing it together with an epoxy glue such as araldite. This can give a high strength joint which may be OK for your application.
            Alan
            #343573
            Tractor man
              @tractorman
              Brett.
              If the part is under strain such as part of the clockwork mechanism I thunk silver solder would be best. But if it’s not load bearing I would agree that gluing the break would be far easier.
              I use JB weld which is available on line but apparently Halfords do a similar type metal epoxy that is just as good. Worth a try before the problem of silver soldering if you’ve never done it before.
              Best regards Mick
              #343574
              Speedy Builder5
                @speedybuilder5
                As Neil says, but after the first heat up to dull red, let it cool and wire brush the joint to remove the 'burnt off' carbon, then re-heat to silver solder or braze.
                BobH
                #343575
                Stewart Hart
                  @stewarthart90345
                  Posted by Neil Wyatt on 27/02/2018 23:06:41:
                  As Neil said but give the parts a good wire brushing to get rid of the ash/crud after it cools, I've used this method and it worked for me.
                  Stew
                  #343611
                  speelwerk
                    @speelwerk
                    The few times I have done it I sandblasted the parts first. Niko.
                    #343663
                    Brett Hurt
                      @bretthurt41827
                      thanks for the info
