Calling all Little John and other Raglan users
Home › Forums › General Questions › Calling all Little John and other Raglan users
Viewing 9 posts - 26 through 34 (of 34 total)
  • #820674
    john fletcher 1
      @johnfletcher1
      Not a Raglan owner but helped a friend who had one a few years ago, and he gave me a part number for the special drive belt ROULUNOS ROFLEX 22H7025 DR433. He asked me to pass on the details.  Ted
      #820677
      David Senior
        @davidsenior29320
        Thanks Ted. Could you ask your friend whether his lathe is a Little John Mk1 or Mk2 (which use one length of belt) or the later Raglan 5″ (which uses a longer belt)
        colinbowles
          @colinbowles
          Hi
          I have a Raglan 5″ lathe which I use freaquently for hobby and semi retired work, it would be great to get advice and guidance on how to keep it in good working order.
          #843268
          David Senior
            @davidsenior29320
            Hi Colin
            I see you are already registered on the Raglan forum, so just ask away there and you should get informed answers.
            colinbowles
              @colinbowles
              Thanks for the reply Dave
              A first question, where do i get new backplates for the Raglan 5″?
              #843275
              David Senior
                @davidsenior29320
                I’m not aware of a supplier – you just make your own. Cutting the thread can be a little daunting but it is certainly possible. I rotated the spindle manually when I made one. I now have an electronic leadscrew fitted to my Raglan 5″ so I’m hoping that it should be somewhat easier now. I intend to make some more so maybe I should get into the workshop and just do it!
                David Senior
                  @davidsenior29320
                  I should have pointed out that the quality and fit of the thread is not critical. The 2 location diameters and the spindle mating face do all the aligning – the thread just pulls the chuck on.
                  There is a drawing in the manual that gives the dimensions (if you don’t have the manual it is available on the Raglan forum)
                  David Senior
                    @davidsenior29320
                    Colin
                    I’ve put a little write-up on making a backplate for the Raglan lathe on the Raglan forum, in case it helps
                    https://raglanmachinetools.freeforums.net/thread/855/chuck-backplate
                    #843402
                    not done it yet
                      @notdoneityet
                      They do occasionally come up on epay but often sell at ridiculously high prices (IMO).
