calling 254 Myford owners
Home › Forums › Manual machine tools › calling 254 Myford owners
  • #14293
    duncan webster 1
      @duncanwebster1
      #550513
      duncan webster 1
        @duncanwebster1
        Some time ago I bought a Myford dividing head, it's about time I got a chuck for it. I've got a suitable chuck, and bought a threaded backplate from RDG, not much more expensive than buying a lump of iron to make it from. I now need to machine the register. Myford used to supply a 4 MT arbor with a ML7 nose so you could use old chucks on your new lathe. This would be ideal for this one off job, but I haven't got one. Anyone got one I could borrow? If not I'll have to machine a dummy nose from scratch. Obviously I'll pay postage both ways
        #550520
        DC31k
          @dc31k
          Myford spindle nose adaptors with 2MT are available.
          Open-ended 4MT to 2MT reducers are available. In a different context, they might be known as a spindle nose bush.
          #550527
          IanH
            @ianh
            Hi, I think I have one of those, it has a 12 tip thread on the big end and is tapped for a draw bar at the other.
            Ian
            #550593
            Chris Pearson 1
              @chrispearson1
              Or get somebody with a small Myford to do it for you.
              Dare I say that an adaptor can be pretty useful if you want to keep the workpiece centred in the chuck and transfer to the dividing head?
              #550595
              duncan webster 1
                @duncanwebster1
                Thanks to those who have got back. Just to clarify, there is an adaptor which I have from MT4 to MT2 which allows you to use Myford collets, but it doesn't have the parallel bit or a shoulder so you can't mount chucks. I'm trying to do this on the cheap, so DC31K's suggestion was not immediately appealing, but I take Chris's suggestion, good point. I've added some pictures to clarifycollet adaptor (small).jpg
                This is not what I need, I've already got one!
                needs the parallel portion and flange
                #550612
                John Haine
                  @johnhaine32865
                  Does the 254 have a large threaded nose like the big bore S7? Mine came with a big bore to standard nose adapter with MT2 taper if that would help?
                  #550615
                  DC31k
                    @dc31k
                    How cheap is cheap? 4MT to 2MT bush is £10.96; Myford spindle nose on 2MT is £16.50, both from RDG.
                    #550616
                    DC31k
                      @dc31k
                      Posted by John Haine on 20/06/2021 18:54:44:
                      See this recent thread:
                      https://www.model-engineer.co.uk/forums/postings.asp?th=173446
                      #550618
                      JohnF
                        @johnf59703
                        Duncan, I do have the MT2 spindle nose adaptor and I think – have to check an MT4 step up sleeve 2-4 0r 3-4 have to check, if its of interest please PM me.
                        duncan webster 1
                          @duncanwebster1
                          Well I very nearly bought one, but the RDG ones don't have provision for a drawbar, and I've fallen foul of turning something held on MT without drawbar before. A very kind member of the forum has offered to lend me one. What a fine bunch of chaps you all are.
                          #551516
                          Chris Pearson 1
                            @chrispearson1
                            My apologies if anybody objects to my thread drift.
                            Myford is offering some taper turning attachments, which seem to have been cluttering up their shelves. £400-odd could be a lot for something which you use once or twice, but nice to have even if never economically sound. smiley
                            #551945
                            duncan webster 1
                              @duncanwebster1
                              Job done, adaptor back on it's way to the kind chap who lent it to me. I did consider making an MT4 to Myford nose but the MT4 blank arbors aren't big enough.
