BSP tap needed
BSP tap needed
Home › Forums › Beginners questions › BSP tap needed
  • #539701
    pgrbff
      @pgrbff
      I need to make a single threaded hole, 1/4"bsp into the side of a 1 1/4" BSP iron pipe.
      As this may be the first and last time I will probably need to tap a 1/4" bsp hole will a single taper tap do?
      Edited By pgrbff on 14/04/2021 15:06:52
      #10800
      pgrbff
        @pgrbff
        #539703
        Martin Kyte
          @martinkyte99762
          I should think so, if not just grind the end off a little.
          regards Martin
          #539704
          Alan Wilkinson 1
            @alanwilkinson1
            Yes if you can get through far enough to get the full thread
            #539711
            HOWARDT
              @howardt
              If you an get one buy a second tap, a little less taper lead than a taper tap.
              #539713
              Dr. MC Black
                @dr-mcblack73214
                Have you considered going as far as you can with a taper tap and then grinding away the taper sufficiently to use what's left to create the full thread?
                #539728
                pgrbff
                  @pgrbff
                  As a woodworker I don't often need taps. I want to make up a mixing valve for my sandblaster and need to tap a 1/4" BSP hole in the side of a 1 1/4" iron tube. I'd prefer to buy only one tap and I'm not sure which would be the best choice. Are BSP threads always tapered?
                  #539735
                  Steviegtr
                    @steviegtr
                    Posted by pgrbff on 14/04/2021 17:18:26:
                    No, there are tapered & none tapered. This has been covered before somewhere on here.
                    Steve.
                    #539740
                    Robert Butler
                      @robertbutler92161
                      Where are you based, I have a selection of BSP taps.
                      Robert Butler
                      #539746
                      not done it yet
                        @notdoneityet
                        You could make a flat on the pipe, weld on a suitable fitting and drill through?
                        #539761
                        David George 1
                          @davidgeorge1
                          Hi Steve. Have you thought of using a T joint. 1 1/4 x 1 1/4 x 1/4 My local pipe suplier will thread the 1 1/4 pipe for very little whilst I wait and not a lot of money. You will get a better seal as a pipe is not that thick pipe section and not many threads.
                          David
                          #539793
                          Hopper
                            @hopper
                            You need to look at the fitting you want to screw into the tapped hole. If the male thread on the fitting is tapered, you will need BSPT tap. (T for tapered.) Most ordinary black or galv pipe fittings will be the tapered thread, put together with thread tape or sealant.
                            #539808
                            not done it yet
                              @notdoneityet
                              Posted by Hopper on 14/04/2021 23:28:37
                              If it is not an arduous duty, make a flat as use a parallel thread plus a sealing washer?
                              #539967
                              pgrbff
                                @pgrbff
                                Posted by Robert Butler on 14/04/2021 18:21:32:
                                Robert Butler
                                Thanks but I'm in Italy. At least I can find BSP taps here, German seem to be reasonably priced. Normally I buy used English manufactured from Ebay when I other than metric.
                                #539969
                                pgrbff
                                  @pgrbff
                                  Posted by David George 1 on 14/04/2021 20:06:58:
                                  David
                                  I'm trying to keep the airflow in the 1 1/4 pipe as smoth as possible. I need to tap a small valve into the pipe to allow air in, and be able to adjust how much air, to hopefully create a venturi effect to open up glass beads flowing through the pipe.
                                  #539998
                                  David George 1
                                    @davidgeorge1
                                    Hi is this for some type of sand/glass bead blasting machine. If it is, I have made one in the past and I would have thought that adding air into an already pressurised pipe would have been counteractive to the flow and venturi effect further back down the pipe, perhaps slowing down suction on venturi. The biggest problem I had was moisture in the media/air and clogging after a while of not using it clearing set beads.
                                    David
