Broaching small items
Home › Forums › Beginners questions › Broaching small items
  • #333714
    Andy Carruthers
      @andycarruthers33275
      I would appreciate advice on how to create a small ie 3mm x 3mm square hole in 1.6mm brass sheet please. More specifically, sample tools and techniques to do the job.
      I would like to create "make-up" keys for Mortice locks, these have 7 segments for a 5 lever lock – I imagine a 3mm x 3mm steel bar which the brass sections ("bits&quot slide onto with a cap screw holding the segments together
      Alignment is important as "bits" must not be offset from each other
      Whilst "make-up" keys are available through the trade, they are expensive and the variety of locks ie 7 lever gun cabinet locks and some safes make it an expensive proposition buying any number of them
      Your thoughts please
      #9015
      Andy Carruthers
        #333717
        Brian Wood
          @brianwood45127
          Hello Andy,
          Use one of the square files from a good set of needle files and open out a drilled hole.
          Regards Brian
          #333718
          roy entwistle
            @royentwistle24699
            Should be no trouble with a three square file. If several holes must line up, make the holes in larger pieces first
            Roy
            #333723
            Andy Carruthers
              Thank you – Occam's Razor I was over thinking the problem
              #333731
              Bizibilder
                @bizibilder
                https://www.youtube.com/watch?time_continue=1&v=MYI1slVGziU
                Hopefully the above will help.
                Edited By Bizibilder on 24/12/2017 10:32:19
                #333743
                MW
                  @mw27036
                  Traditionally it would've been done with a series of steel cutting broaches with the edges gradually tapering towards a fully square profile.
                  #333750
                  Gary Wooding
                    @garywooding25363
                    I'd use a piercing saw.
