Bridgeport Mill BR2J Head Vibration
Home › Forums › General Questions › Bridgeport Mill BR2J Head Vibration
  • #327681
    Absolute Beginner
      @absolutebeginner
      Just wondering if anybody else out there with a Bridgeport Mill noice any head vibration. ?
      Mine is particularly noticeable at lower speeds. You can watch the light attached to the side of the column wobble.
      It seems to reduce as the speed is increased from low 450 rpm upwards.
      The head in itself dosent seem that noisy in fact it runs quietly I think……so just wondering if anyone else had come across the vibrations?
      Or can suggest what might be causing it ?
      Thank you
      Gary
      #25634
      Absolute Beginner
        @absolutebeginner
        Vibration at lower speed
        #327686
        Chris Evans 6
          @chrisevans6
          My machine had a slight tendency to do the same. Cured by mounting the machine on rubber pads, then used 2mm metal sheet as shims to level it.
          #327689
          Absolute Beginner
            @absolutebeginner
            Thanks Chris.
            Good suggestion there. My machine is currently resting on a concrete floor, I did think about rubber feet but hadn't bothered. Perhaps that might help. Appreciate the suggestion.
            Gary
            #327707
            Anonymous
              Assuming a varispeed head then 450rpm is right at rhe bottom of the upper speed band. So one end will have the belt on the outside of the discs, and the other end has the belt on the inside of the discs, close to the drive shaft. Any corrosion or dents on the edges of the discs will cause vibration, as will the belt if it is contacting the drive shaft. I don't run my Bridgeport much below 500rpm on the top range; not so much due to specific vibration, but it just doesn't sound too happy.
              PS: My Bridgeport just rests on a concrete floor
              Edited By Andrew Johnston on 17/11/2017 20:53:35
              #327711
              Absolute Beginner
                @absolutebeginner
                Hi Andrew,
                Interesting comments
                Thanks
                Gary
