Good Morning all,
There are two different though related processes being discussed here, and hence the debate over the heat input.
Brazing is where you heat the whole item – or enough of it locally – to get the bronze filler to flow into the work. This implies you have a general temperature suitable to get the filler to melt and flow. Very difficult to control where the filler goes, other than a thin layer on the surface of the hot area, or pulled by capilliary action into a fit-up gap. A Sievert or a Bullfinch gas torch would be suitable for this process, provided the burner was chosen appropriately.
Bronze WELDING, where the heat input is very localised (though possibly with the use of a pre-heat to control distortion etc.) This uses the heat of the flame to melt the filler metal locally, so it fuses but by manipulation of the heat you can build up a fillet or an insert of bronze material locally. This is the process you can see Adam (Aborn 79) or Keith Rucker use for the task being discussed.
The necessity for a significant localised heat input makes bronze welding the territory of oxy-acetylene, though you can do it with oxy-propane if needs must. But you need the small intense heat source to locally melt the filler deposit as you add more to build up the weld metal in layers. The skill is in manipulating the heat input so as to melt enough but not too much.
TIG brazing is the same process – the terminology is very confused. However the visibility difficulties with having to use a welding mask to see anything at all means that using a TIG torch as the heat source is a whole lot more difficult.
Having built up the filler sufficiently then you machine it back appropriately to give the gear tooth profile. You might well end up with a gear tooth of bronze amongst a whole lot of iron ones.
Keith Rucker does exactly this job in one of his planer restoration videos, he makes the point that you need to grind the parent metal out to get back to good material to which the bronze weld will adhere.
The tooth resulting looks a bit odd; provided the process is done without overheating the silicon bronze filler rod and burning off the alloy constituents the filler is potentially stronger than the parent cast iron.
HTH Simon
Edited for typo
Edited By Simon Williams 3 on 01/06/2020 10:38:01
