Boxford headstock spanner
Home Forums Manual machine tools Boxford headstock spanner
  • #65158
    Stuart C
      @stuartc
      I suspect anybody that has had to dismantle or re-assemble a boxford lathe may have had the same problem as myself and i am wondering if anybody has the answer.
      There are 2 screws holding the Boxford headstock onto the bed, the right hand one is difficult to get to, has anybody got a drawing of the spanner that needs to be made to get at it, or have another solution.
      #11755
      Stuart C
        @stuartc
        #65175
        Terryd
          @terryd72465
          Hi Stuart,
          I merely took an old spanner of the right size and bent it at right angles so that I could access the bolt. I will look in my toolboxes that I have left following a workshop fire and see if I can find it. If I do I will post a picture. To remove the bolt is a nuisance rather than impossible. I had to dismantle my machine to move it and it didn’t really take very long. I should be able to search tomorrow and see if I can find my modified spanner,
          Also I have some Boxford manuals and books (including ‘Know Your Lathe) and you are welcome to a copy if you let me have your address via personal messages.  That is if you would like a copy.  There is also an article on how to build your own 3 1/2″ lathe which is quite interesting.
          Best regards
          Terry
          Edited By Terryd on 08/03/2011 00:03:19
          #65180
          Chris B
            @chrisb73862
            I heated a spanner and bent a deep offset to clear the bed when I stripped both of my Boxfords in the past. I think I had a cut down spanner as well.
            Chris
            #65183
            Terryd
              @terryd72465
              Hi Chris,
              You’re right, I now remember cutting down a cheap (ish) spanner as well so that I could get the sweep to loosen the nut a little at a time. Fiddly job but didn’t take long I think.
              Terry
              #65184
              Stuart C
                @stuartc
                If I make a cranked spanner, am I right in thinking the height offset should be about 45mm to clear the bed, and about 30mm from the side of the screwhead to clear the headstock
                I still have some BSW spanners, I’m thinking it’s 5/16″ BSW ?
                When I speak to Boxford tomorrow I’ll also ask them what they used.
                #65188
                Chris B
                  @chrisb73862
                  I suppose one other way would be a “crows foot” wrench if the square hole came out far enough to clear the front face of the headstock or make your own by welding a socket to a cut down ring end of a combination spanner.
                  CB
                  #65192
                  Richard Parsons
                    @richardparsons61721
                    I do not know the Boxford lathe too well, but a friend long ago and far away bought one. It was delivered in several boxes. To put it together he borrowed my 5/16 – 3/8” whit dynamo spanners. One was a curved ring which let you get at the lower fulcrum nuts at the front and rear of the dynamo and at the lower bolts on the starter. The other was a right angled open ended spanner which allowed you to get at the fulcrum bolts. I think you can still get the spanners and Crow foots (they are in my Cromwell catalogue but only in Metric sizes). It might be a thought to have a new bolt with a head made to fit the one of these sizes
                    #65643
                    Freddybear
                      @freddybear
                      Some 15 years ago when I first aquired my AUD MK2. I had the same problem.
                      My solution having no oxy gear was to cut and weld an old whitworth spanner to do the job.
                      Even with this spaner, it was still a pain to tighten up.
                      I am planning a much overdue overhaul of this machine soon.
                      If my (metric) crows foot set won’t fit, I will use the welded spanner to get the bolts off again, but then I am thinking that I will do one of the following:
                      A) Machine 2 custom shlouder bolts with long shanks and a metric hex on the end.
                      B) Use long versons of whitworth bolt and turn some spacer tubes ( to bring head down below the bed)
                      C) Possibly (if available) get a pair of hex cap head bolts. (I suppose I could re-thread a larger metric hex cap head bolt) I would then use a hex adaptor in a ratchet.
                      Anyone have any better idea’s.
                      #65647
                      Stuart C
                        @stuartc
                        does yours not have a solid bed under the headstock, if so I don’t think those options would work
