Boxford 280
Boxford 280
Home Forums Workshop Tools and Tooling Boxford 280
Viewing 25 posts - 1 through 25 (of 33 total)
  • #304156
    Lee Goulding
      @leegoulding74917
      Hi All
      Me again..
      I've just been stripping and cleaning up the tail stock and Apron Gear Assemply and noticed that the diagram in the manual has a washer 07/010 which on my lathe is not there instead there's a bearing!!
      And also there no EPL 19 waved washer between the handle and the dial gauge
      Thanks
      #18560
      Lee Goulding
        @leegoulding74917
        #304168
        David Standing 1
          @davidstanding1
          Well then Lee, you're going to have to order them from Boxford.
          PS – you're gonna have a heart attack if you're not careful crook.
          #304226
          Lee Goulding
            @leegoulding74917
            tell me about it.. loving it though in my new man cave..
            #304227
            Lee Goulding
              @leegoulding74917
              would you suggest removing the bearing David and replace with the brass washer thats listed in the manual?
              Thanks
              #304229
              David Standing 1
                @davidstanding1
                Lee
                If it works, I'd always stay as the original setup.
                Pictures of man cave required………wink 2.
                Edited By David Standing 1 on 26/06/2017 08:56:25
                #304231
                Lee Goulding
                  @leegoulding74917
                  ok David thanks it just confused me when i took it apart then looked at the diagram and found the brass washer should be next in sequence but all i had was a bearing.
                  Theres defo two Wavey washers missing after the wheels which i think are a must to have so will get them
                  Thanks for your help..
                  #304236
                  Nick_G
                    @nick_g
                    My X10 has a bearing also. – I presume that this may be an undocumented modification by Boxford.
                    My advice would be clean it, relube it and pop it back leaving well alone.
                    Nick
                    #304246
                    Lee Goulding
                      @leegoulding74917
                      Hi Nick
                      I can confirm after speaking with Boxford that dependent on age it is a change that is on some machines and the manual is outdated so bearings are in place of some documented washers etc
                      Thanks for the advice as always appreciated
                      #304386
                      Lee Goulding
                        @leegoulding74917
                        Hi All
                        Update!! Lathe now running with inverter and control but as you can hear from the video clip there's a whistle coming from the motor when I increase the speed..
                        The electrician used SY screamed cable about 1 metre
                        Any idea how to cure this
                        Thanks
                        Edited By Lee Goulding on 26/06/2017 22:17:08
                        #304388
                        David Standing 1
                          @davidstanding1
                          Lee
                          Did he ground the cable shield at one end, or both?
                          #304390
                          Lee Goulding
                            @leegoulding74917
                            Hi David
                            Wil let you know when he gets back to me as I'm not sure
                            Thanks
                            #304441
                            Lee Goulding
                              @leegoulding74917
                              Hi David
                              Only one end was ground
                              Thanks
                              #304454
                              David Standing 1
                                @davidstanding1
                                Lee
                                Then for starters try grounding both ends, in case that cures it smiley.
                                #304459
                                David Standing 1
                                  @davidstanding1
                                  And if that doesn't work, despite the shielding, you may want to try moving the inverter a bit further away if you have enough slack cable.
                                  #304460
                                  mark smith 20
                                    @marksmith20
                                    My Alexander mill inverter makes that sort of noise(high pitched whine) as well when it reaches speed. I think i only grounded one end of the s.y cable. I dont have a remote pendant on it as yet so just using the inverter controls directly.
                                    Edited By mark smith 20 on 27/06/2017 10:28:50
                                    #304466
                                    Lee Goulding
                                      @leegoulding74917
                                      Hi David
                                      Thanks for that and will try both ends and the inverter is about a metre away from the motor as I was told that the cable from the inverter to the motor should be around a metre
                                      Thanks
                                      #304467
                                      Lee Goulding
                                        @leegoulding74917
                                        Hi Mark
                                        Thanks for that and hopefully can get it running quite and will update with fix if and when it happens 👍
                                        #304572
                                          Posted by Lee Goulding on 26/06/2017 22:14:09:
                                          You will always get noise from screamed cable, try getting some mute cable.
                                            More seriously the shielding or lack of it won't make the motor noisy, but if the inverter is set for a low carrier frequency that can make odd noises. you can reprogram some inverters to use a different waveform and reduce the noise, or at least make it less unpleasant.
                                            Nick_G
                                              @nick_g
                                              Now don't get jumpy or panicky. ………………………….. Yet.
                                              But on that video it was not the motor noise. It just on the whole sounded a bit 'rumbly' somewhere than the one I have. frown
                                              Maybe the video audio or something as simple as the change gears having the incorrect spacing and want a tad of adjustment.
                                              Nick
                                              #304586
                                              Lee Goulding
                                                @leegoulding74917
                                                Hi Nick
                                                Who am I to disagree what you say and I really wouldn't have a clue how to adjust the change gears but a noise is defo coming from the motor since the inverter has been wired up.
                                                I know phone audio tends to enhance things which it has
                                                Thanks
                                                #304597
                                                Nick_G
                                                  @nick_g
                                                  I did not mean the motor noise. It was something additional.
                                                  But I do know on mine that the change gears incorrectly set can make noises of varying types depending on if there is too little or excessive clearance between them. Can also effect surface finish on the part being turned.
                                                  Easy to adjust and lube though. – Get yourself a can of motorbike chain lube as its a none fling lubricant and is ideal for those open gears.
                                                  Nick
                                                  #304601
                                                  Lee Goulding
                                                    @leegoulding74917
                                                    Hi Nick
                                                    Ok will have a look at the gears and get some lube and I've just got this from the inverter man regarding the. Lose from the motor.
                                                    Its likely to be just the carrier frequency because it is chopped up DC it is quite normal.
                                                    Parameter 72 changes this it has a range of 1 to 15. I set it mid range to 7.
                                                    You will need a module to change any parameters.
                                                    #304605
                                                    Lee Goulding
                                                      @leegoulding74917
                                                      Hi Nick
                                                      I've just had a look at the gears.. Wow!! Not a clue 😂
