Posted by Raymond Anderson on 14/07/2021 17:06:44:
Well Michael as a Bricklayer/ Mason I can safely say they will have to be removed and replaced. Its not a major operation to do that. 100mm angle grinder and diamond blade cut in to the beds/joints as far as you can [ will probably be about 30mm ] then a ripping iron or a small SDS Plus breaker and chisel. If that is common brick they will not be rated F2 which are fully frost resistant , more likely to be F1. They actually look like seconds. The damage you see is in no way related to mortar strength its purely not being frost resistant. the old freeze and thaw syndrome.
Thanks, Raymond … especially for confirming my view about the irrelevance of the mortar strength.
Every time I look at this wall it looks more evident that it will have to come down … and having seen, today, that several of the blue ‘engineering’ bricks that top it are loose; I don’t think that will be a difficult task !!
Paying for the rebuild will be soul-destroying though.
