Black 5 Tender 5″ with 7 1/4 top on
Home › Forums › Locomotives › Black 5 Tender 5″ with 7 1/4 top on
  • #1433
    Ron Hancock
      @ronhancock63652
      #199741
      Ron Hancock
        @ronhancock63652
        p1070071-001.jpgp1070072.jpgp1070072.jpgI have just bought a Tender of the dreaded EBay when i got it found the Bogies are 5" as it was advertised but the rest is 7 1/4 is this often done it was only advertised as a 5". It was cheap and the rest is very well built so could make new Body in time i can see the benefits of having larger Tank for water and Coal just wondered if this is a common thing as not seen before
        Edited By Ron Hancock on 08/08/2015 21:31:40
        #199762
        julian atkins
          @julianatkins58923
          hi ron,
          are you sure it is a 7.25"g body? it doesnt look too big to me but just a perhaps freelance 'big' 5"g tender. if the price is right im sure it will 'do' and better than having no tender at all and delaying completion. you can always have a go at a finescale accurate 5"g LMS tender after completing the loco, and in the meantime you have a ready to run tender.
          cheers,
          julian
          #199775
          Boiler Bri
            @boilerbri
            How did you manage to photograph it in the front room without getting caught? 😱
            #199780
            Ron Hancock
              @ronhancock63652
              Posted by julian atkins on 08/08/2015 23:54:29:
              hi ron,
              cheers,
              julian
              You may be right Julian it's 1 1/2 inches wider than the plans i have so took it to be a 7 1/4.
              The Bottom has been well built wheels brakes axle boxes ect.
              As for price i had put £500 bid but it went for just £200 i was shocked as cost of frames wheels ect worth far more.
              I should have the Tender to go with the Loco at some point its sitting in a Garage but due to problem of my late Uncles will have to wait till probate finished.
              I hope to get my boiler in next three to four weeks and wanted a tender so i can run it this will do nicely.
              Ron
              #199781
              Ron Hancock
                @ronhancock63652
                Posted by Boiler Bri on 09/08/2015 07:49:30:
                You would never believe it but my wife loves it in the living room she says she is proud of the work we have done on it but she is one in a million.
                #199791
                david homer
                  @davidhomer12226
                  If that is the Fowler 3500gal tender the dimensions Martin Evans gave for it for the Royal Scot was 22 7/16" x 9 1/2" wide over the running boards with the body dimensions being 21 5/8" x 9".
                  David
                  #199803
                  KWIL
                    @kwil
                    Something wrong with your drawings then Ron. If you took 1.5" off the width, the tank would be as wide as the track!!
                    #199828
                    Boiler Bri
                      @boilerbri
                      Charles PooterI only manage the conservatory passage😊
                      #199831
                      Ron Hancock
                        @ronhancock63652
                        Posted by david homer on 09/08/2015 10:25:22:
                        David
                        Hi this one is 10 1/2 inch wide 26 inch long and 7 inch high from running board.
                        I was told at our club it's a B1 tender but oversize
                        Ron
                        #199832
                        Ron Hancock
                          @ronhancock63652
                          Posted by KWIL on 09/08/2015 11:43:12:
                          It's 10 !/2 wide track is 5"
                          Ron
                          #199833
                          Ron Hancock
                            @ronhancock63652
                            Posted by Boiler Bri on 09/08/2015 17:15:16:
                            Would love a Conservatory but wife says my 22ft by 22ft workshop takes enough room !!!
                            #199836
                              Are you sure Ron? It looks in proportion in the photos. What is the buffer spacing?
                              Ron Hancock
                                @ronhancock63652
                                Posted by Neil Wyatt on 09/08/2015 18:24:04:
                                6 !/2 inch the frames and everything lower is 5" just the Top is wider 10 1/2 inch 7 inch high and 26 inch long.
                                I think it still be ok to use the work is excellent just larger than the rest at the club Neil
                                Ron
                                #199893
                                  I'm sure it will be OK , the difference doesn't jump out at you .
                                  Ron Hancock
                                    @ronhancock63652
                                    Posted by Neil Wyatt on 10/08/2015 08:49:24:
                                    Thank you neil sure once Boiler and cab on will look better
                                    Ron
                                  Home › Forums › Locomotives › Topics
