Black 5 ready again to run
Home › Forums › Locomotives › Black 5 ready again to run
  • #321372
    Ron Hancock
      @ronhancock63652
      Well going to Run this Sunday after a load of many problems,
      I have had the Crank done that came loose rebuilt axle pump new boiler cladding now fits.
      Just received a new Injector from Paul Pavier that really is suposed to be the very best,
      I have had so many that did not work i have had piping changed plus i also changed also clacks ect.
      I sent three to Julian Atkins who found the ventura in the tops where to big and would not work,
      Julian going to send two back going to return to suplier see if they will change or refund,
      I borrowed one from Julian that did pick up gave me hope.
      Bought another from Manchester i think that one will be ok its a black one same as reeves.
      Will fit the new one on Sunday and see if i have now got every thing sorted. I have run it on axle pump Ran fine till axle pump went and crank came loose.
      I have now repainted it and for the first time feel very confident in it.
      Roll on Sunday at Coalville its even forcast 21 deg so looks like its all going the right way.
      We will see
      Ron
      #1645
      Ron Hancock
        @ronhancock63652
        #321382
        Jeff Dayman
          @jeffdayman43397
          Good luck Sunday Ron.
          #321383
          Brian Sweeting 2
            @briansweeting2
            Fingers crossed for you, not that you really need. Sounds like you've got all the bases covered.
            Hope it's a good day.
            #321384
            Ron Hancock
              @ronhancock63652
              ronThanks Guys Fingers crossed
              #321396
              Brian H
                @brianh50089
                All the best with it Ron. You deserve it to work like a dream!
                #321406
                Ron Hancock
                  @ronhancock63652
                  Thank you Brian hope it does
                  Ron
                  #322093
                  Ron Hancock
                    @ronhancock63652
                    Well Ran my Black 5 Sunday with new Injector from Pavsteam worked perfect picked up every time. Loco Ran ok but really lacking power. I had 7 adults on it realty struggled to pull them even in full forward gear. Guys at the Club suggested the Valve timing might be out so going to read up on it see if it’s set right. Other than lacking power she Ran ok. Back to drawing board get my head into books and learn how to set Valve timing. Ron
                    Edited By Ron Hancock on 18/10/2017 11:28:23
                    #322108
                    Brian Sweeting 2
                      @briansweeting2
                      Well done, mind you six adults could have needed a diet
                      #322110
                      Ron Hancock
                        @ronhancock63652
                        Like the Driver he he the Ladies where very slim
                      Home › Forums › Locomotives › Topics
