Bevel gears
Bevel gears
Home › Forums › General Questions › Bevel gears
  • #362220
    Rod Ashton
      @rodashton53132
      Dear fellow scrou……. recyclers. What can be cannibalised to get a pair of right angle bevel gears for a steam engine ball governor? Need to be about 8 to 12 mm. major diameter. Your experienced advice appreciated.
      #26092
      Rod Ashton
        @rodashton53132
        Bevel gears
        #362222
          Is it really worth searching around for then when you can get a new brass pair for a fiver, maybe less with a bit of searching on e-bay.
          Also as they are really under no load you could cut your own with a home ground tool, just freehand ground by eye.
          Edited By JasonB on 15/07/2018 07:15:38
          #362277
          Perko7
            @perko7
            Radio-controlled car suppliers/hobby shops usually have a range of stock gears to suit the wide variety of R/C cars on the market. Worth a try, usually nylon/brass/steel/diecast alloy available.
            #362295
            Rod Ashton
              @rodashton53132
              Jason – That is a really useful site. Thank you.
