Best quality M2 taps
Home › Forums › Workshop Tools and Tooling › Best quality M2 taps
  • #307362
    Brian John
      @brianjohn93961
      What brands of M2 taps do members use ? I never have any trouble with M3 or larger taps but I have had a few M2 taps break. Brass and cast iron are usually okay but steels often cause problems. I use plenty of Tap Magic and I go very slowly, about 1/8 turn at a time….back and forward…..but I still sometimes get a broken tap.
      #18586
      Brian John
        @brianjohn93961
        Strongest and least likely to break.
        #307365
        Thor 🇳🇴
          @thor
          Hi Brian,
          I have a few non branded serial taps that work well, but not as well as my Dormer taps. Have you tried using 1.7mm tapping drills in steel?
          Thor
          #307372
          richard 2
            @richard2
            Morning Brian
            Have just tapped a number of M2 holes – PRESTO taps from Cutwell.
            Excellent taps and superb service.
            No relation – just a very satisfied customer.
            Richard 2.
            #307381
              Although I have dormneones in teh larger sizes they get a bit spendy as the size reduces so I use Volkel ones M2.5 and below, usually get them from Rotagrip via their e-bay shop
              #307382
              Neil Lickfold
                @neillickfold44316
                Using a 1.7mm drill does help a lot to make the taps last longer. Especially when tapping steel.
                speelwerk
                  @speelwerk
                  Posted by JasonB on 16/07/2017 08:08:40:
                  Small size good quality taps are indeed spendy, the time you bougth them in the hardware store around the corner is long gone. I returned the 1.4mm ones from Bergeon since 110 euro ex. VAT was a shock. Niko.
                  #307393
                  Chris Evans 6
                    @chrisevans6
                    Plus 1 for Volkel and Rotagrip.
                    #307399
                    Brian John
                      @brianjohn93961
                      Yes, I always go up to 1.7mm when tapping into steels.
                      #307408
                      Neil Lickfold
                        @neillickfold44316
                        I have found on small stuff the tapping compound makes a difference. I like the old Tap magic and the other that is good is Relton Rapid tap fluid.
                        Gary Wooding
                          @garywooding25363
                          I created THIS PDF some years ago. It presents a set of tables comprising: Metric/Inch conversions, and tap/drill sizes of Metric, Imperial, B.A., and BSP threads. The tapping sizes are calculated to give a 65% thread engagement for sizes up to about 3/8", and 70-75% thereafter, as per Tubal Cain's Model Engineer's Handbook. The sizes are not copied from the book (which contains at least one error) but are calculated from scratch.
                          The PDF consists of 2 pages that I've printed on both sides of a single sheet and laminated to make a useful workshop crib sheet. It's my "goto" source of information for threading data.
                          #307452
                          Brian John
                            @brianjohn93961
                            The charts I have used in the past give the tap drill as 1.6mm. That PDF gives the tap drill for 2 x 0.4 as 1.7mm. So should I still be ''going up a size'' to 1.8mm when tapping into steel or use 1.7mm for all metals including brass ?
                            Edited By Brian John on 16/07/2017 14:02:34
                            #307456
                            Gary Wooding
                              @garywooding25363
                              Posted by Brian John on 16/07/2017 14:01:17:
                              No, the calculation for M2/0.4 is for a 65% thread engagement. I've used it in steel many times.
                              #307459
                                Posted by Gary Wooding on 16/07/2017 11:37:46:
                                Thanks Gary; copy taken!
                                Cheers,
                                KWIL
                                  @kwil
                                  I think it would be helpful IF when you are talking about taps you state whether you are using straight or spiral fluted taps.
                                  There is no doubt that spiral fluted taps clear the chip better than straight, especially as you get smaller diameter.
                                  #307536
                                  Brian John
                                    @brianjohn93961
                                    Are spiral fluted M2 taps likely to be any stronger than straight fluted M2 taps ? There can't be much difference.
                                    Why do we make straight fluted taps if spiral taps clear the chip better ?
                                    Edited By Brian John on 17/07/2017 05:56:27
                                    #307547
                                    roy entwistle
                                      @royentwistle24699
                                      Obviously cheaper to produce
                                      Roy
                                      #307567
                                      Ian S C
                                        @iansc
                                        Hi Brian, you'll likely find the ones most available will be Australian made Sutton brand, they seem to be fairly good. For brass, copper, aluminium, and any ductile metal the strongest taps are the Threadflo type of fluteless taps.
                                        Ian S C
                                        #307568
                                        KWIL
                                          @kwil
                                          Spiral flute taps flow the cut material forwards in the case of spiral point and backwards in the case of the spiral flute, practically none stays fixed in the flute like a straight flute, hence less jams and breaks.
                                          #307572
                                            Posted by Brian John on 16/07/2017 02:08:16:
                                            I too break small taps. Being weedy little things they're vulnerable to jamming due to swarf, not being straight in the hole, and going blunt. My breakage rate dropped after:
                                            1. Using a tap stand to keep the tap at right angles to the hole
                                            2. Taking the tap out completely every few turns (or as soon as it resists) and removing swarf from the flutes and hole. I find Steel and Aluminium swarf more troublesome than Brass.
                                            3. In steel, over-sizing the hole (unless strength matters)
                                            4. Dumping taps as soon as they show any sign of bluntness.
                                            Depending on how it feels, I usually make more than 1/8 turn reversals, perhaps up to a full turn. I look for the point where I get a tiny snick on reversing the tap. Not sure if that's right but it works for me.
                                            KWIL
                                              @kwil
                                              The tiny snick is the large "chip" being broken away from the parent material
                                              #307672
                                              Ian S C
                                                @iansc
                                                The thing with Threadflo taps in ductile materials is that there is no chips, the thread is formed by pressure as are external rolled threads, the thread will be stronger than a cut one. no good on most steels, or cast iron, but ok on most stainless steels.
                                                Ian S C
                                                #307679
                                                Chris Evans 6
                                                  @chrisevans6
                                                  It has been years since I last broke a tap. I always use a tapping paste rather than any of the liquid tapping agents as I do not find the liquid as effective. As stated above back off a good turn to break the chip, 1/8th of a turn is just the movement of the flute and not cutting the chip. If taps start to feel tight on winding them out it is time to bin them.
                                                  #308007
                                                  Phil Boyland
                                                    @philboyland37326
                                                    Another vote for Volkel. Brilliant and HSS too.
                                                    #308022
                                                    IanT
                                                      @iant
                                                      Yes Chris,
                                                      If you mean the 'green' stuff (Trefolex) – give me some of that every time!
                                                      IanT
