best pressure gauge?
Home › Forums › General Questions › best pressure gauge?
  • #356119
    Terry Chapman 2
      @terrychapman2
      I want to replace the pressure gauge on my 'Minnie' traction engine,Ive seen them at Macc models for £30.00 or Stuart at £43.00. Is the extra worth it/ Dont mind paying the extra if its justified?
      Thanks
      Terry
      #26011
      Terry Chapman 2
        @terrychapman2
        #356132
        Mike Lightfoot
          @mikelightfoot72419
          Thats fine but why replace it, when you have the boiler test the inspector should mark Max working pressure on it you could scale it down from that ?
          #356151
          Terry Chapman 2
            @terrychapman2
            Ive checked it at 50 psi and its only just moving off the rest ie 15 psi.Its over40 yrs old so cant complain?
            #356154
            Paul Kemp
              @paulkemp46892
              Posted by Terry Chapman on 01/06/2018 21:22:17:
              Terry,
              Have you connected the gauge directly to a reference or are you connecting it through the siphon? Due to the small bore of the siphon it us not uncommon for them to become blocked with scale and hence give a false reading! The age of a guage shouldn't be detrimental it's the hours in steam that will wear it out! If it's been sat 20 years doing nothing it's not deteriorating if it's been dry stored?
              You can get a replacement from various sources but worthy of note its best to get one with a pre marked red line on the dial as if you open up an unmarked one to mark it the supplier usually says your warranty is void! Miniature Pressure Guage Supply Co offer pre marked gauges of various sizes and styles. (No connection but have purchased from them in the past).
              Paul.
              #356175
              Terry Chapman 2
                @terrychapman2
                Hi PaulI, checked to make sure the syphon pipe was clear and connected it to my compressor with an accurate gauge already fitted.As I say,The compressor gauge was 50 and the model was 15 psi.
