Best jointing compound for difficult joints
Home › Forums › Locomotives › Best jointing compound for difficult joints
  • #298146
    Alan Wood 4
      @alanwood4
      I have a close tolerance but significantly overlapping joint I wish to seal that is inaccessible for soldering or brazing. Is there a compound I can use that will withstand steam pressure ?
      Thanks
      Alan
      #1607
      Alan Wood 4
        @alanwood4
        #298166
        Hopper
          @hopper
          Stag jointing compound? But it depends on the size and type of joint, steam pressure, pipe vs plate, vibration, etc etc etc. Bit more info on the specific appllication would help.
          #298167
          duncan webster 1
            @duncanwebster1
            High temp silicone, available from Halfords. Let is set before you pressurise it.
            #298178
            J Hancock
              @jhancock95746
              As DW says, High Temp Silicone, use as directed.
              Stag has its uses but it is a bit 'dated' now.
            Home › Forums › Locomotives › Topics
